Double image repair video, please explain
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hi guys, just stumbled on a video on YT where they repair "double image" on LCD tv's by cutting some panel flat cable lines, anyone can explaint it to me why they do it? Only thought that gets into my mind is they cut some of the "data" lines and tv doesn't reproduce them on panel. But doesn't that lower the tv resolution i.e. some lines on lcd panel wont be displayed at all.
    https://www.youtube.com/watch?v=yLH9...I#t=280.255458
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Double image repair video, please explain
    It must have some effect on reducing the screen resolution but that is the price you pay to have a watchable image.
    • rimwall
      Sony KD-65x7500D - double image - Tcon or Panel?
      by rimwall
      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
      11-18-2025, 02:09 AM
    • jason123
      Vizio V555-H1 - Horizontal lines then double image bursts
      by jason123
      Hi there,
      I think it might be a bad panel but I thought I'd ask before I chuck it..
      thin colored horizontal lines bottom and thin section on top. As it runs warmer, you can see some ghosting or double image. Right hand side of the screen darker then brighter (backlight is always on, so it's the actual LCD that gets darker and brighter)
      Replaced the Main board, because I had one handy, no change.
      Is it worth replacing TCON? disconnecting ribbon on one side of the panel, the lines appear still on the other side (unplugged side.)
      12-15-2022, 03:53 PM
    • Cornito
      Samsung UE55RU8000 reboot and then double image after heating up
      by Cornito
      Hello team,
      I'm back with another tv and another problem.
      I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
      First, reboot issue, I use tape Method to find out the right side that cases the issue.
      Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
      Then double image reduce in height and move to the top.
      The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
      When I...
      03-31-2024, 01:37 PM
    • x_orange90_x
      Vizio V585-J01 dancing lines and image doubling
      by x_orange90_x
      I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
      Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
      Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
      I swapped...
      06-12-2024, 07:57 AM
    • DrvLikHell
      Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
      by DrvLikHell
      Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
      The...
      02-05-2025, 01:44 AM
