Panasonic Th-42pz700u 7 blinks.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I picked this tv up today with the 7 blink fault.
    The sc board is TNPA4250. When I disconnect SC2 I still get 7 blinks.
    Connect SC2, disconnect the 2 buffers, 7 blinks.
    I check the 2N5307 transistors on the SC board and 6 of them read shorted (meter beeps).
    They ones that seem shorted are the top 5 on the left.
    Does this sound like a bad SC board?
    Service manual says 7 blinks could be SC, SU, SD or D board.
    Both of the board LEDs for the SC and the SS are lit, which on other Panasonic models usually indicate they are ok.
    Any advice?
    For some reason this double posted. Might have been an iPad glitch.
    Can a mod delete this one?
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • canadaboy25
    Panasonic TC-P54VT25 No image. A or D board?
    by canadaboy25
    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
    01-17-2021, 01:06 AM
  • Biruslapio
    Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
    by Biruslapio
    Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
    It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
    It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
    02-16-2021, 09:44 PM
