Sanyo dp55441 "no signal" please help!
  • Georgia088
    • Sep 2014
    • 109
    I have a Sanyo dp55441. A lightning storm came by the other day and got several electronics in the house. This tv included. It wouldn't do anything when power was pressed. I took tv down, took back cover off, and visibly checked everything and nothing stood out. I plugged power up and tv came on. Everything seemed to work. I could change input and it would display and then show "no signal". So I connected it to different sources and still get "no signal". I have tried all hdmi ports. Composite Video ports and the USB port and they all show no signal.
    Any ideas?
    The main board's numbers are listed as 431c4169l02. They are nearly impossible to find.
    Questions:
    Do you think this is what is causingissue?
    Is there a way to check if this is bad?
    Is this part compatible with other similar parts?
    Thanks so much for any help!
  • Diah
    • Feb 2013
    • 6435
    Re: Sanyo dp55441 "no signal" please help!
    one test need to do, when you plug USB storage check the LED indicator of the USB it tun on and blinking or not, this test to confirm if 5 Volt there in the signal circuit.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      The mainboard probably took a big hit and the chip that controls the HDMI is not working.
      http://www.ebay.com/itm/Sanyo-55-DP5...-/161447837497
      $55 not a bad price! Its the L02 version. If all connectors look visibly the same then it will work.
      • Georgia088
        • Sep 2014
        • 109
        Thanks for the help!
        I plugged a usb into the port and it did light up. It also would allow me to access the usb info. However it still wouldn't show video through the hdmi or component ports. Any idea?
        Also, that link with the main board for $55 will be compatible if it looks the same even though the p/n isn't exactly the same?
        Thanks again for all your help!
        • Diah
          • Feb 2013
          • 6435
          let we narrow it more, did you play photo or movie or music via USB, we need to confirm the audio and video process at the main processor not damage.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            That board comes out of the same tv so it will work.
            • Georgia088
              • Sep 2014
              • 109
              Update:
              I put in usb and I can display a jpg image file. It will not show any of my MP4 video files on the usb to try to play them. Any ideas what video format the tv will play through usb?
              Thanks!
              • Diah
                • Feb 2013
                • 6435
                yes USB designed on this set of Sanyo play only Photos, nothings wrong with it, was my mistake to wrote music, video file.
                please read this link how to inter service ( Factory ) menu, and first focus on point No (8) Source Calibration of PC or YPbPr/YCbCr terminal signal ... if it give you OK will be good, if it give you result NG . then go to point No (6) NVRAM CLEAR. to rest the set complete.. as this set had much do with firmware to syncs HDMI and calibration them . also give it try, before you go to option change or inspection hardware.
                https://electro-medical.blogspot.de/...ode-power.html
                also please put it in mind don't blame only yours Sanyo TV of this fault, try to test yours HDMI out put source set. and HDMI cable too. to be sure that fault belong to the TV 100%.
                • Georgia088
                  • Sep 2014
                  • 109
                  Ok. I followed the instructions from your link clicked source calibration, did a nvram clear and reset to default settings. I put tv on video 3 and pc and did source calibration and got "pattern ng" I changed to every source on the tv from different output sources and can't get anything to provide video or audio to the tv. From the usb I can display an image and all menu function work on the tv. What should I check next? Does this still sound like this is a main board issue?
                  Thanks again for all of your help!
                  • Diah
                    • Feb 2013
                    • 6435
                    yes its main boards issue, did yours RF ( tuner ) working or also cut no signal ?
                    • Georgia088
                      • Sep 2014
                      • 109
                      It is also no signal. Also, the link provided for the replacement board on eBay is a L01 version. Will this work as mine is a L02. If I find a L02 that comes out of same model tv as mine and looks identical it will work?
                      I really appreciate your help!!!
                      • Diah
                        • Feb 2013
                        • 6435
                        you can try make for him offer moe cheaper.. and you know now how to deal with service men, so you can change any if the replacment boards need other settings...
                        .. i would suggest since you are going to change the MB, take it out from the set, and with hot air gun, heat the main processor very well , it may got bad soldering as the pins all downside.. try it if not go to replace
                        • Georgia088
                          • Sep 2014
                          • 109
                          So, what you are saying is that all other versions that look the same as mine will work with my tv. I just may have to change the settings? In the factory mode service menu? Is this correct?
                          Thanks again!
                          • Diah
                            • Feb 2013
                            • 6435
                            yes, also it may work direct with out need any change. .. of course if its not defect .
                            • Diah
                              • Feb 2013
                              • 6435
                              between on ebay you can find yours version also new version 03..
                              you can see all HDMI line going to the IC in the middle, this one heat it with hot air gun... give it try and save $
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                The heatgun trick will not work. It only works when the chip became so hot that the soldering got loose.
                                This particular set has been struck by lightning. Or atleast a high current went through ( probably ) one of the devices that were connected via hdmi. The chip that controls the hdmi is shorted and needs replacing. If that is too difficult then replace the mainboard.
                                You can always try what Diah says as that would save you a lot of money but with high current through the mainboard im sure it will never work. Im sure that one OR more chips on the board are fried.
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  Dear Moreno83, the IC not shorted, because it succeed to switched USB and display its contents, if he got Lighting from HDMI , you can see on the MB all HDMI line going direct to the IC. there is also big possibility one pin under the IC cracked by spark. since he should go to replace the boards,, any try will cost him Zero.
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    No hard feelings Diah , i get your point but with lighting atleast 1 chip gets shorted. It will take more parts with him
                                    Hope a reflow will work! Fingers crossed.
                                    • Georgia088
                                      • Sep 2014
                                      • 109
                                      So is there a way to test and see what part is bad with a multimeter?
                                      Thanks again!
                                      • Georgia088
                                        • Sep 2014
                                        • 109
                                        Ok. Unfortunately the heat gun didn't fix problem. Still get pattern ng. Is there a way to test to see if and which chips or boards are bad?
                                        Thanks!
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • karthur
                                          Sanyo DP55441 - No brightness control
                                          by karthur
                                          Recently picked up a Sanyo DP55441. Set has a few issues:
                                          1. When I turn it on, I always have to select either "Store" or "Home" on the menu (see attachment).
                                          2. It forgets which input I was using last, so I have to change the input setting everytime.
                                          3. The controls for Brightness, Contrast, Saturation, Hue and Sharpness are not available from the menu (see attachment).
                                          Besides these issues the set works good, no other issues that I know of.
                                          I am thinking all three are related and its probably the main board. I have looked...
                                          06-19-2022, 08:09 AM
                                        • JayPoorJay
                                          Converting +/- 5v to a Usable Hz Signal
                                          by JayPoorJay
                                          Good morning.
                                          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                                          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                                          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                                          08-07-2022, 08:35 AM
