Hello all!
So this is a 51" plasma tv I picked up from some one to try and fix. Thought it would be a good learning experience. I suppose a LCD/LED TV would have been easier to troubleshoot then a plasma! Oh well, diving in head first.
So here is the story, I tested the current on the VS and VA test points on the main power board with the Y-Main board disconnected and the voltages they read are actually double what the sticker reads before they both drop down to around 22 and 12.
The logic board green LED flashes every 5 seconds with it connected to the Y-Main board, but once disconnected it will flash every second, thus telling me there is an issue with the Y-Main board.
With the Y-Main board connected I read around 22V at the VA test point and 0V at the VSCAN test point. The sticker on panel says the VSCAN should be reading -190 I believe.
This is a replacement Y-Main board I just got in the mail. Looks like all caps were replaced and no sign of a bulge in the slightest.
What should I do next to further isolate issue? Thanks in advance!
