Swedx LCD XV1-19TVW - screen flash loop
  • ocf
    • Jun 2016
    • 157
    A friend gave me this TV to look at, it recently started exhibiting an issue, when switched on it appears to be stuck in some sort of burn in mode. The screen flashes in a loop between black, white and then RGB Stripes going from dark to light showing across the screen.
    It definitely appears to be a test or burn in mode as there are no artifacts or other issues showing on the screen.
    TV takes 12v DC external power
    There were a few burst 220uf caps on the mainboard that I replaced but this didn't make any difference.
    I cant find any schematics on the board or service manual, there are also no replacement boards form the usual sources.
    Interesting thing to note, when I heated the board with a hot air gun and powered the TV on it did not show the colour loop and started up ok, I got the swedx splash screen and the TV accepted commands from the remote. After 10 seconds of staying on it immediately went back to the flashing burn in mode. Definitley something faulty on the mainboard, what would be affected by heat like this? Do EEPROM chips only react well to cold?
    Any advice on what to check next? I have a good grounding in reading schematics and would consider myself far from a beginner when it comes to electronics, throw some ideas at me!
    thanks in advance
    OCF
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Re: Swedx LCD XV1-19TVW - screen flash loop
    Sounds like you need to reflow the mainboard. Heating it up may have cleaned up some broken solder joints.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Sounds like a faulty regulator, have you tested them ?
      • ocf
        • Jun 2016
        • 157
        No I haven't done any checks on these, I'm not great at picking out parts and testing without a schematic.
        If I post an image of the board can you point out the voltage regulators.
        All the best
        OCF
        • ocf
          • Jun 2016
          • 157
          I'm quite sure that the board didn't get close to any temp that would allow solder to melt. Board probably got about 60-80C max.
          I have an SMD hot air station on the way which should help me narrow down the issue as I could heat individual parts.
          Thinking to start with the voltage regulators as suggested by ReeceyBurger123
          • ocf
            • Jun 2016
            • 157
            I've located all the voltage regulators on the board they are all CX1084 and CX1117 and all labeled ADJ. I have taken a look at data sheets for the chip and I cant work out what voltge the Adjustable regulators should be outputting. Does the output voltage depend on the resistor used between Adj and Output terminls or do I have this all wrong
            Voltage regulator part numbers I found on the board -
            CX1084 ADJ 7226Y
            CX1084 ADJ 7265Y
            CX1117 ADJ 7382Y
            Any advice welcome, would pictures help?
            • ocf
              • Jun 2016
              • 157
              pics, most of V Regulators are on right hand side of board if that helps
              https://postimg.org/image/tmomz5h4n/
              https://postimg.org/image/ipnbadud3/
              https://postimg.org/image/ryphki393/
              • ocf
                • Jun 2016
                • 157
                One of the regulators is showing 0.15v on input pin, 0.9 on gnd and 2v on output, this seems wrong?
                Dont vregs take a minimum voltage above the required output voltage to drive the regulator itself, so if this has 0.15v and 2v output surely its problematic?
                I'm spitballing here, just trying to make sense with my limited knowledge
                • ocf
                  • Jun 2016
                  • 157
                  any further help please?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ok that reg you tested is good, the tab is normally the output on them. What about the others ?
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • ekozeko333
                      by ekozeko333
                      🧠 What I’ve Done So Far
                      Flashed...
                      06-21-2025, 02:48 AM
                    • corrize
                      Nikon D800 camera - flash don’t work and capacitor don’t charge
                      by corrize
                      Hello, I'm stuck in troubleshooting…
                      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                      10-01-2022, 10:02 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • praveenramavath
                      Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                      by praveenramavath
                      Hello All,
                      I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                      https://www.hifivision.com/threads/m...-screen.98243/
                      Troubleshooting Summary: Majority Internet Radio - Flash Chip
                      04-26-2025, 09:08 AM
