Magnovox 50 MV314X makes pop sound when turning on
  • phil@philporter.com
    • May 2013
    • 113
    Inherited a dead Magnovox - model 50MV314X/F7. No signs of life - assumed it was power supply as this has been the case with about 10 I have previously repaired. A new board was less than the repair kit.
    Found an inexpensive PS on ebay and installed. When turning on it blinks red like trying to turn on and then there is a brief static pop out of the speaker and nothing happens. Any ideas what might cause this? Don't mind getting a main board if it it suspect - they are only around $20, but if it could be something else would try that first. Thanks.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8180
    Re: Magnovox 50 MV314X makes pop sound when turning on
    my guess is you have a bad main board. For prices like this it's a no brainer to get a new board.
      • May 2013
      • 113
      Thanks. I agree - I ordered a main board for $20.
        • May 2013
        • 113
        New main board and no change. Still blinks red light like trying to start and a few seconds later a static pop comes out of the speakers. Can anyone tell me how to check the power from the PS to the main board? Thanks
          • May 2013
          • 113
          I suspected a bad PS since it is doing the same thing with both the old main board and new main board. Now it turns on and the Magnavox logo comes on and HDMI text at top left of TV, but after a few seconds it has that static pop out of the speakers and turns off. Not sure where to go, but this is a relatively new TV and want to give to my son and daughter-in-law expecting first child. Any help is appreciated. Would pictures help?
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • slimmy182
            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
            by slimmy182
            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
            Looking on google I found this:...
            01-14-2023, 11:55 AM
          • mrtek
            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
            by mrtek
            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
            11-26-2024, 09:58 AM
