Dead LG 47LD650 ?
  • bianchi77
    • Jun 2016
    • 1121
    Dead LG 47LD650 ?
    Hi Guys,
    This LG 47LD650 only showing logo at the start and then freeze there ...
    What do you reckon I should fix ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Dead LG 47LD650 ?
    Mainboard issue. Possibly firmware.
    • Diah
      • Feb 2013
      • 6575
      Ignore the firmware, you have bad soldering at main boards, many people face this and they solved with Bake The Board
      on of them who succeed here his article http://zedic.com/lg-42dl550-fix-repair/
      • capwizard
        • Jun 2016
        • 1991
        My Dear friend Diah: Ignore the oven bake,Try to use a paint stripper much better.
        I got this tip from ReeceyBurger123
        Common issue on these boards is bga solder failing on the main processor which is under the heatsink, you could try reflowing it to see if it sorts the issue.....
        Real working case:
        https://www.badcaps.net/forum/showpo...6&postcount=47
        I checked, they used the same LGE3549 LGE3549X L6E3549XS LGE3S49XS LGE3549X5 LGE3549XS BGA IC Chip for mircoprocessor (IC501).
        [Tech Tips] First do reflowing if not work then reballing. This LG BGA processor has server heat dissipation problem, even they do use metal casing.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Real working case:
          +1 good info, never use the oven method its known as a bodge job !
          • capwizard
            • Jun 2016
            • 1991
            In this case, a paint stripper is batter than the oven, because we knew the location of the problem at.
            But don't get me wrong...you need two paint strippers ( one on top and other-one at bottom), two PID controllers,two K sensors ,and old Compaq case.
            I am embarrassed to show my dirty pictures of 6 years old home-made BGA rework
            station. It work like a champ. With this baby,you can enjoy a coffee then came back.
            Try to update to this one
            https://github.com/0xPIT/reflowOvenController
            • bianchi77
              • Jun 2016
              • 1121
              Ok, so you guys suggest, reballing or reflowing the main processor ?
              I saw the chip on the left hand is misalign and the position from the top is not flushl ? ...
              Is it because of over heat ? The chip code : XD Engine LGE 7378 LF,
              I'll try reballing it....and we'll see
              • bianchi77
                • Jun 2016
                • 1121
                @capwizard, thumbs up!, what heater do you use for "compaq" ?
                • bianchi77
                  • Jun 2016
                  • 1121
                  Photos :
                  • capwizard
                    • Jun 2016
                    • 1991
                    Reflowing is temporary repair mainly for customer, for whom might come back later, and reballing is for permanently repair.
                    @bianchi77
                    Oh My Sweet Lord! you're fast. not this one, is the one in the center with heat sink(picture of post #4) and metal-casing, call main video processor.
                    The one you've took out is lvds to VGA digital signal processor.
                    I wish your BGA rework-station has optical alignment system.
                    • capwizard
                      • Jun 2016
                      • 1991
                      @bianchi77
                      harbor freight 1500 Watt Dual Temperature Heat Gun. (on sale for $7.xx)
                      http://www.harborfreight.com/1500-wa...112-96289.html
                      Two fans inside the Heat Gun are dc 12v . So, I use ATX power supply 3.3v ,5v,12v for fan speed contral (high, mid, low control). (I should use variable power supply). Cost under $50.00. It becomes one of the most useful tool for me. Two PID controllers do most work of it.
                      Try to use 90 degree prisms from DLP TV or iphone dual cameras to make an optical alignment system, never have time to get it.
                      • bianchi77
                        • Jun 2016
                        • 1121
                        optical alignment system == > how does it look like ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          How can I reball if the chip is smaller than my stencil ?
                          • capwizard
                            • Jun 2016
                            • 1991
                            You don't need to put it back which you've taken out is LVDS processor , tv will work without it.(you will get white screen and can power on and off)
                            Put some flux on edge of the main processor, then reflow it.
                            I've done it about a week ago by reflow only and work perfectly.
                            [Tech Tips] by ReeceyBurger123
                            I was inspired by him,before I did a lot of HP laptop VGA reflowing, never ever think can be do on TV.
                            • bianchi77
                              • Jun 2016
                              • 1121
                              so what's the function of LVDS processor ?
                              • capwizard
                                • Jun 2016
                                • 1991
                                Display the picture and video for TV
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  Home-made BGA alignment video system + microscopic video
                                  https://www.youtube.com/watch?v=I8hH8W1jlFw
                                  http://bgamods.com/forum/viewtopic.php?f=62&t=3848
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    ok, why it can work without LVDS ?
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      29 pcs/set BGA Universal Stencil Directly Heating Stencils
                                      http://www.aliexpress.com/store/prod...322335068.html
                                      Multi BGA Reballing Stencil
                                      http://www.aliexpress.com/item/5pcs-...08.4.71.bp90zZ
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        ok, why it can work without LVDS ? (only showing logo at the start and then freeze there)
                                        O ..My bad... we need to get the freeze logo back then fix the original problem.
                                        In my case, I have no picture on the TV but test pattern was passed. reflowed it then works.
                                        • kela777slk
                                          Zbook 17 g5 logo freeze need help please
                                          by kela777slk
                                          Hi. I have buy laptop from ebay. Issue in boot logo freeze, not entering to diagnosetic menu or other menus - esc, F2, F3 F10 F12 . Try combination keys win+b - no success. Try flashing bios and EC - no success too. Only freeze logo, whrite entering menu in down side lcd but not entering, then if press enother key ( F3 , white legacy op rom boot and not entering, then if press any F 1-12, only whrite optional menu but not entering.
                                          What is problem - I don't know. Caps lock and num lock flashing 4-5 times and reboot, then flashing power button many times, need 5 sec press for hard reset......
                                          02-26-2023, 04:37 AM
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
                                        • Verlengsnoer
                                          Bios splash/logo change
                                          by Verlengsnoer
                                          at firs, i hope this is the right place to post my question.
                                          Im looking for a tool to change the bios logo.
                                          everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                          i know that HP has a build in option to change the splash logo.
                                          but i want to change the manufacturer logo to an own logo.
                                          I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                          10-28-2022, 09:52 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • conghuyms
                                          MacBook Air A2179 stuck logo , pls help me !
                                          by conghuyms
                                          Hey everyone,
                                          I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                          When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                          I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                          11-05-2025, 08:30 AM
