Backlight LED Replacement tip
  • london-freddie
    • May 2015
    • 472
    Not sure if this is in the correct forum but here goes. Changed 3 leds on a 40" Samsung yesterday. did same last week to 3 samsung tvs with no problems, however when all put back together and tv powered up on this set I had 3 distinct bright spots on the screen, these lined up with the areas that I had replaced the leds. Took tv and screen apart again to see what was wrong, fired the backlights up and all seemed ok with them, however when looking at the leds wearing two pairs of dark sunglasses it was obvious that the 3 leds I changed were brighter than all the others. Long story short I had not replaced the clear plastic led covers exacly centred on the leds. removed the led lenses and replaced them exactly in the centre of the led and problem solved.
    Therefore when replacing leds make sure that lens cover is exactly in the centre of the led.
    Maybe you all know this i I am the only one that has been caught out with this
  • egils
    • Jun 2016
    • 4
    • Sweden
    Re: Backlight LED Replacement tip
    Thanks for the tip about the sunglasses. Sounds like good practice to test the backlight before putting the screen back together with all the screws and covers.
    • Hamie
      • Apr 2014
      • 1383
      Very rarely do I solder a new led onto the existing strip.
      The stacking method is faster and eliminates the chance of bright spots.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Watch my videos mate, head on to my channel to find how to directly replace them:
        https://www.badcaps.net/forum/showth...tacking+method
        • pni
          Backlight panel diffuser melt by backlight leds broken
          by pni
          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
          10-12-2025, 12:08 AM
        • hollox123
          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
          by hollox123
          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
          1. Laptop keyboard doesn't work
          2. The backlight on the laptop keyboard doesn't work
          3. The x2 side LEDs (red) on the laptop don't work
          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
          But I am strongly aiming that it is somehow a BIOS-related problem,...
          05-11-2025, 08:05 AM
        • signal.quest
          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
          by signal.quest
          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
          03-17-2024, 10:14 AM
        • nicke74
          Samsung UE55JU6875 issue after backlight replacement
          by nicke74
          Got problem with a samsung UE55JU6875 after replacemant of backlight
          I have done similar replacement several times before without any issues but now I got video problems after the replacement and do not understand why
          Attached picture of the problem
          Is it a bad panel or any issues with the T-con card or ribbon cables or bad connections?.
          I have tried to replace both ribbon cables from T-con to panel without any difference.
          Any ideas?
          The only misstake I might have done was forgot to remove the ribbon cables from the T-con card before...
          04-02-2023, 11:03 AM
        • RetroComputingGrotto
          LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
          by RetroComputingGrotto
          This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
          On fitting the new LED strips I plugged in the TV was blinded by the light!!
          It was only when I partially put it all back together (including the screen) that...
          10-23-2024, 04:17 AM
