LG 50PS3000 top half of screen black - Help Please!! Noob alert!
  • MChohan
    • Jul 2016
    • 9
    • Uk
    Hi all
    The LG 50PS3000 is around 5 years old, working fine from day one with no issues. One night after a few hours of use, the top half of the screen became pixilated and then turned black. The bottom half and audio is perfect.
    I have opened up the tv after researching a bit and have ordered and tried replacing the upper Buffer board to no success. Funnily enough once I put the original buffer board back in the top half now works intermittently.
    For example...after a cold start the top half starts working after a few minutes. Then it'll go black for 10-30 seconds seconds (sometimes with a random broken up line of pixels, sometimes not) and then back to a full screen for 10-30 seconds.
    Any help would be much appreciated! Unfortunately I am new to opening things up and tinkering so please don't be offended by my stupidity.
    Before anyone asks I am a complete novice who was extremely proud when changing the HDD on his PS3.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50PS3000 top half of screen black - Help Please!! Noob alert!
    Hi mate, wait for Ali E to chime in he knows about this failure. Its the Ydrive control buffers failing.
    • MChohan
      • Jul 2016
      • 9
      • Uk
      Thanks ReeceyBurger123
      • MChohan
        • Jul 2016
        • 9
        • Uk
        Any chance someone can get Ali E's attention?
        • R_J
          • 9515
          There are a lot of threads about this model, search your model number and read the threads, there might be some info their. looks like it could be the ysus, if the upper part of the screen does come up and work sometimes I doubt its a buffer board (ic) problem, they usually fail and don't come back.
          https://www.badcaps.net/forum/showth...light=50PS3000
          • MChohan
            • Jul 2016
            • 9
            • Uk
            Update...had an engineer come in and look (friend of a friend) talking about how the screen needs replacing and the gas has gone from the plasma....possible?
            Tried a 3rd buffer board to no effect. So you guys think it's worth getting a second hand Ysus board from eBay to try?
            I don't have the tools or knowledge to test it I don't think...unless someone can explain in simple terms.
            I've read through other posts already to no avail
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Bullshit he doesn't know what hes on about ! Show him this message and tell him to stay away from Tv's if he has no idea what hes on about !
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                The Ydrive is the issue NOT THE BUFFER OR PANEL ! The panels dont wear out like that. Do what I said and run the test patterns if the lines are there likely the Ydrive at fault. To run the test remove the Lvds wire from the Mb and jumper the ext gen pins on the control board then plug the Tv in the patterns will come up.
                • MChohan
                  • Jul 2016
                  • 9
                  • Uk
                  Update...
                  I've taken off and reattached the Ysus board...getting impatient with no progress. No difference!
                  I've attached pics below...could you kindly point out which bits I need to use (and how) to run a test image please.
                  • Raulnn
                    TD Systems K50DLG12US half black and half white screen
                    by Raulnn
                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                    01-20-2024, 04:49 PM
                  • HTR-Informatique
                    by HTR-Informatique
                    02-09-2025, 06:51 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • VcemPzd
                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                    by VcemPzd
                    Hello everyone !
                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                    04-28-2025, 10:14 AM
                  • Demonith
                    Adler-43ae99s Plz help me fix it ! half black screen
                    by Demonith
                    Hi i am not expert on fixing i am learning just to make shore about but every help is welcome so i have here Adler-43ae99s and what i done is replace the bad capacitors on mainboard and backlights now what i have problem is its all black no image no sound so i have try testing it on RCON flat cables when i remove LEFT its black and white but when i remove RIGHT its all black now i am on dead end here and i am feel let down on my self with this one i hope some one will help
                    02-10-2025, 12:12 PM
