Samsung LN40B550K1 Vertical Lines
  • samsagaz
    • May 2016
    • 9
    • Argentina
    Hey guys i have an Samsung LN40B550K1 TV that have vertical lines.
    Someone know what can be happend? Is possible that changing the Tcon will fix the issue?
    Or looks like its an LCD Problem?
  • CapLeaker
    Leaking Member
    • 8214
    Re: Samsung LN40B550K1 Vertical Lines
    unhook one side of the tcon, check the picture, then vise versa and check it again. Also squeeze the TV at the edges or wiggle the tab bonds.
    • samsagaz
      • May 2016
      • 9
      • Argentina
      Thanks ! if do that and dont get fixed, what can be broken? Is possible an LCD Fault?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yes likely the panel here, I have see of couple of these myself with panel issues not very relible.
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
          09-07-2024, 05:50 AM
        • Anonmis
          Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
          by Anonmis
          Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
          The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
          12-01-2023, 04:31 PM
