Samsung LN40B550K1 Vertical Lines
  • samsagaz
    • May 2016
    • 9
    • Argentina
    Hey guys i have an Samsung LN40B550K1 TV that have vertical lines.
    Someone know what can be happend? Is possible that changing the Tcon will fix the issue?
    Or looks like its an LCD Problem?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Samsung LN40B550K1 Vertical Lines
    unhook one side of the tcon, check the picture, then vise versa and check it again. Also squeeze the TV at the edges or wiggle the tab bonds.
    • samsagaz
      • May 2016
      • 9
      • Argentina
      Thanks ! if do that and dont get fixed, what can be broken? Is possible an LCD Fault?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yes likely the panel here, I have see of couple of these myself with panel issues not very relible.
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          Sadly it has vertical lines at the left and one line in the middle-right.
          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
          I have factory resetted the TV as well but also with no luck.
          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
          09-07-2024, 05:50 AM
