Vizio P50HDTV10a 10" wide vertical bar
  • Treydogg77
    Treydogg77
    • Mar 2013
    • 99
    • US
    Hello again everybody! I've got a Vizio P50HDTV10a with a vertical bar on the screen. Anybody had this issue before and what would cause this? Power supply, and or main board? I have attached a picture, to see what I've got going on!
    Thanks for any help and advice!
    Trey W
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Vizio P50HDTV10a 10" wide vertical bar
    Post a picture of your top and bottom Y buffer boards. More than likely bad Mosfets on the bottom board.
    • Treydogg77
      Treydogg77
      • Mar 2013
      • 99
      • US
      Okay it will be late this evening before I can get those pictures! Dang right, thank you for the lighting fast response Cliff!
      • Treydogg77
        Treydogg77
        • Mar 2013
        • 99
        • US
        Sorry for the delay Cliff. Will this picture work?
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • otaku_nut
          Vizio E701i-A3 fixed but now has red vertical line
          by otaku_nut
          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
          08-19-2025, 06:11 PM
        • brad2157
          Vizio E70-E3 Two white vertical lines
          by brad2157
          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
          Replacement main board - Boots up fine, but starting...
          12-13-2021, 05:11 PM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
