Panasonic L24C28X
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Panasonic L24C28X
    I have Panasonic TH-L24C28x television with power supply unit model no. B109-E09, and Display card model no. 1AA4B10S1000A. Problem is I cannot turn it no, no power on power indicator.
    I measured following on CN3.
    1. PS-ON = 5.0v
    2. GND = 0.0v
    3. GND = 0.0v
    4. 5V = 5.1v
    5. 5V = 5.1v
    6. GND = 0.0v
    7. 12V = 12.0v
    8. 13VA = 13.0v
    9. 13VA = 13.0v
    10. AGND 0.0v
    11. AGND = 0.0v
    12. ADJ = 3.3v
    13. ON-OFF = 0.0v
    14. NC = 0.0v
    Power, Menu, Input, Enter/OK, Vol+, Vol-, Ch+, Ch- all have 3.2v
    I have no idea where the problem exists but I suspect problem is ON-OFF or NC pin.
    Btw there was no voltages on above pins, a 3-leg mosfet K4100 in which pin1 and pin3 was shorted, searched from diagram somewhere found that it is supposed to be a N-Channel mosfet, I counldn't find same part number so I changed with similiar type of N-Channel mosfet and above voltages were present.
    Any ideas to solve this problem please.
  • CapLeaker
    Leaking Member
    • 8218
    Re: Panasonic L24C28X
    Cording to this the tv is on, but the backlights are not getting turned on by the main board. So you have a main board problem
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Any idea to fix it? Or should I change main board?
      Btw there is no sign of life in power indicator.
      • CapLeaker
        Leaking Member
        • 8218
        check the PSU out first. Unhook everything from the PSU and just leave the backlights connected. You need two 1k ohms resistors and solder one between STBY voltage and PSon, the other between Stby voltage and BLon. Plug the psu in and all the voltage rails should be up and the backlights should be on.
        Repairing main boards like that is hard and you need proper smd rework equipment. I am not saying it can't be done, but it is heck easier to get a new main board, than investing in all that time troubleshooting, parts etc into the old board that acts like that.
        If that test passes, go ahead and get a new main board.
        • dspok
          • Jan 2014
          • 553
          • Nepal
          I understand STBY voltage is on/off but what is BLon?
          • marty_cam
            • May 2014
            • 19
            • Ireland
            I would assume the pin which is labelled BL-on for (backlight on)
            • CapLeaker
              Leaking Member
              • 8218
              your BLon is in this case the "on-off" pin.
              • dspok
                • Jan 2014
                • 553
                • Nepal
                Hey, now I 'm able to turn it on but shuts down automatically after 1 minute or half.
                • CapLeaker
                  Leaking Member
                  • 8218
                  explain. Does it work normal for that time period?
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    Turns power LED on, remote power button pressed, Power LED turns green, after few seconds backlight turns on and then TV turns off automatically.
                    In display board there are two components missing C8001 and R8001. Cannot find value of those components see attached.
                    • CapLeaker
                      Leaking Member
                      • 8218
                      The capacitor was a electrolytic SMD type. By the size I am guessing something like 16V 10uF. Watch the polarity! So put something in that is at least 16V 10uf. You can put 25V, 35V or 50V, doesn't matter.
                      The resistor I haven't got a clue. Depends on what pin it goes to on that IC. If we know what IC that is and can find a similar example circuit, we could probably find a resistor that works. If the SMD chip resistor had a 0 (zero) on it, it was just a jumper. Other than that, I guess your gonna be SOL.
                      • dspok
                        • Jan 2014
                        • 553
                        • Nepal
                        I think it is firmware chip, I can only read cFeon F80-100HP.
                        • CapLeaker
                          Leaking Member
                          • 8218
                          The resistor goes to what pin on that IC?
                          For now just put the capacitor in it's place, instead of this jumper wire, see what happens.
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                            11-20-2024, 08:52 PM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • lcdcaps1
                            MacBook pro, AGND
                            by lcdcaps1
                            I am not sure if this has been asked before but, I will appreciate everyone's help from everyone here
                            Macbook schematics show gnd and agnd
                            Upon checking ohm reading from agnd to a screw hole it is connected
                            One of the cap pads goes to agnd that is ripped, so i was thinking to scrape where the agnd pad and make a ground pad
                            If I were to connect this cap that goes to agnd to the scraped pad, gnd
                            what would happen?
                            But why does the schematic show two grounds but practically they are going to the same place?
                            09-26-2022, 03:49 PM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • aa10aa10
                            Panasonic Toughbook CF-33 mk1 BIOS repair
                            by aa10aa10
                            Good day,
                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                            01-21-2025, 06:13 AM
