MacBook pro, AGND
  • lcdcaps1
    • Oct 2011
    • 322
    MacBook pro, AGND
    I am not sure if this has been asked before but, I will appreciate everyone's help from everyone here
    Macbook schematics show gnd and agnd
    Upon checking ohm reading from agnd to a screw hole it is connected
    One of the cap pads goes to agnd that is ripped, so i was thinking to scrape where the agnd pad and make a ground pad
    If I were to connect this cap that goes to agnd to the scraped pad, gnd
    what would happen?
    But why does the schematic show two grounds but practically they are going to the same place?
    Thanks all
  • mon2
    • 14733
    Re: MacBook pro, AGND
    One will be a digital ground while the other is an analog ground. Granted, they are both ground (well behaved ? - small joke); they are different in the following sense:
    https://electronics.stackexchange.co...log%20circuits.
    https://www.analog.com/en/analog-dia...-grounded.html
    • lcdcaps1
      • Oct 2011
      • 322
      Hi
      Thanks for your reply to the post
      I understand there are two grounds, Analogue and digital
      As both grounds are going to the same point would be ok to scrape copper and connect the SMD cap to this ground but this would not be AGND but normal GND
      Thanks all
      • lcdcaps1
        • Oct 2011
        • 322
        Originally posted by lcdcaps1
        Hi
        Thanks all
        Would this be ok to do
        • mon2
          • 14733
          Yes.
          • lcdcaps1
            • Oct 2011
            • 322
            Yes.
            Thanks mate @mon2
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • obelix24
              A2941 Macbook air 15” - 5V 0a
              by obelix24
              I’m working on one macbook air 15” m2 that was water damaged.
              keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
              i’ve put macbook in shelf and order new screen so i can fully repair it.
              Now i got the screen and macbook stays at 5v 0a.
              i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
              i don’t have schematics so i don’t know where to start can someone help me?...
              03-27-2025, 01:19 PM
