lg 47lx6500 backlight with sound no display
  • storexxm
    • Oct 2012
    • 107
    • Vienna
    Re: lg 47lx6500 backlight with sound no display
    another news... when i disconect the lower connection from the main bord the beeping is gone... seems like there were just the speakers
    BUT i saw that the short picture when starting the tv are fine vertical lines...
    when i turn the tv on and off via plug the backlight switches on and off two times.
    with remote control on and off everything is the same BUT the backlight wont start any time...
      • 12098
      • U.S.
      Is this LC470EUS-SCA1 your panel number? is on a sticker on back metal panel sometimes hard to see.
      • storexxm
        • Oct 2012
        • 107
        • Vienna
        yes exactly.... why ?
          Disconnect able to the T-CON board and see what will happen, you will get nothing on the screen of course.
          • storexxm
            • Oct 2012
            • 107
            • Vienna
            already tried... instead of those lines just a black screen with backlight... but backlight wonst stay on.. so.. no change ;/
              • 12098
              • U.S.
              #26
                https://www.badcaps.net/forum/attach...0&d=1596474706
                So some one did work on the power supply board and did a bad soldering works on the board.
                Right now you may have multiple problems and we do not know if other boards are also worked on.
                You can try fixing the power supply board first so you can get the backlights to come on and stay on and hope that backlights LED's are OK.
                I would clean up that soldering works first, it looks like the through hole legs are not solderer properly, I also cannot tell what the MOSFET was replaced or not and if it is replaced with the correct one or not.
                This TV can be a can of worm since we do not know what other bad works were done to the TV.
                If you want to try to fix the power supply board then I will need good clear straight shots pictures of the whole top and bottom side of the power supply board, it is hard to trace the circuit when pictures are shown in sections.
                • storexxm
                  • Oct 2012
                  • 107
                  • Vienna
                  #28
                  here are further shots of the tv-
                  hope u can see whats going on there
                  i will try to find out what the pre owner did to this tv
                    OK, much better pictures, thanks.
                    The section that was worked on is part of LED backlights power supply.
                    I will study the power supply board further and see if it can be fixed, it is getting late here so I will try to follow-up on it tomorrow.
                    BTW, when you unplug the speaker connector, the squealing sound went away, that is not a good sign either. I wonder if the person also try to fix the main board.
                    • storexxm
                      • Oct 2012
                      • 107
                      • Vienna
                      #30
                      I will resolder the ugly section with my iron...
                      yeah the squealing sound is really strange... but when i connect my ps4 and leave the tv in standby it turns on when i turn on the ps4. BUT i have to hit the input key on the remote control blind until i can hear the ps4 menu sound.
                      -> shoudnt the tv switch automatic to the right channel by itself ?
                      when i leave the tv a few minutes on the main processor cooler on the main board got really, really hot... is that normal?
                      Am i right to say there is a chip for audio output ? And that the Video Procesor maybe completely dead...?
                      • storexxm
                        • Oct 2012
                        • 107
                        • Vienna
                        #31
                        resoldered... nothing changed... without a scematic its hard to know if the replaced pieces were right :/
                          Not all TV will automatically switch to the new input source when new source is connected.
                          The heatsink should not get to be too hot to touch.
                          The speakers are driven by amplifier IC.
                          As I indicated, this TV may have multiple problems so I do not know how much of your times, our times, and the money you want to spend on this TV.
                          • storexxm
                            • Oct 2012
                            • 107
                            • Vienna
                            #33
                            i am going to give it away... takes too much time and place in my flat =)
                            • triplefour
                              by triplefour
                              09-13-2023, 10:43 PM
                            • Ierwin
                              by Ierwin
                              05-13-2025, 03:31 PM
                            • arctor
                              samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                              by arctor
                              hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                              04-26-2025, 05:22 AM
                            • triplefour
                              TCL 75S421 has sound but no backlight not even a flash
                              by triplefour
                              TCL 75S421
                              PSU BOARD: 40-L402H8-PWD1CG
                              it shows not even a flash of backlight when powering up.
                              but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                              testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                              unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                              i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                              with mb connected, PSON...
                              11-17-2023, 09:54 PM
