50ps60
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    50ps60
    Im looking at a buddys lg 50ps60. He said it wont turn on. I got it and it turns on, but the display is dim.
    When menu is on, the middle third of screen is clear( but dim and fuzzy ), and the left and right thirds have red transparent vertical segments, which match up with thee bottom buffers.
    I can get pics of everything if needed. Vsus and va are spot on.
    Does anyone know what the problem is?
    Grainny display makes me think zsus, but whats with the red segments?
    I will leave it to THE PROS here. Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 50ps60
    Yes Zsus issue.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Re: 50ps60
      Thanks R.B.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: 50ps60
        No problem, normally on them if its the board Im thinking of. Theres three transistors and 2 resistors that need to be changed to fix it.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Re: 50ps60
          I will check#'s tonight when I get home from my favorite watering hole, unpluged of course. Thanks again.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Re: 50ps60
            Got a zsus board today. Put it in screen lit up brighter than before, still has red vertical cloumns on the outside(left and right) 2/3 of screen(transparent), then shuts off after 20 seconds.
            Screen still looks washed out .
            Might have a bad one. They do take returns.
            I can post any pics you need tomorrow, screen and boards.
            What do you think Reece?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              Re: 50ps60
              well.... bad news. Panel is blown. Gutted and packed up.
              I might have to wait at least a week or two to use them.....lol!!!!
              maybe two years, but, at least I have them. Thanks for the help!!!!
              • jm1234
                Projection display radio - some segments not lighting up
                by jm1234
                alarm clock radio Oregon Scientific RRM320P, it projects the time on the seiling.
                However only part of the segments is lighting up. Any idea what could be behind this issue?
                Note I'm NOT talking the main display here....
                11-11-2025, 04:21 AM
              • alfredomfr1
                TV Plasma LG 60PN5000 ZSUS 15v missing
                by alfredomfr1
                All Voltages are OK except ZSUS 15v.
                YSUS board disconnected still 15v missing.
                ZSUS was replaced: 15v missing.
                Any help will be appreciated...
                04-29-2022, 11:26 AM
              • reessi
                LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
                by reessi
                Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
                Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
                If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
                If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
                12-13-2017, 01:18 PM
              • Salvatore057
                plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                by Salvatore057
                I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                I am lost, should I change the YSUS board? Is the YSUS board damaging...
                04-29-2018, 01:29 PM
              • JDC
                LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                by JDC
                Make and Model: LG 60PB6650-UA
                Issue: Turns on, no backlight, can hear static (no channel)
                I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                09-13-2018, 02:12 PM
