plasma hpt5054 no pict only sound
  • panson
    • Mar 2012
    • 20
    • usa
    does anyone have a link on have to change the buffers on the plasma hpt5054
    or how to troubleshoot it? I have no picture only sound also there is a green light on the y mod
    Thank you all
    *** Today for me Tomorrow for you,*** Ji Ji
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: plasma hpt5054 no pict only sound
    Search....
    https://www.badcaps.net/forum/search...archid=6572998
    • panson
      • Mar 2012
      • 20
      • usa
      Originally posted by cliff_hootarski
      it says .... Sorry - no matches. Please try some different terms.
      • cliff_hootarski
        • Jul 2006
        • 411
        OK, put hpt5054 in the forum search feature.
        • panson
          • Mar 2012
          • 20
          • usa
          I will try TKS
          • panson
            • Mar 2012
            • 20
            • usa
            found d5602 diode in y board shorted is this usually goes bad ? found also 2 ic chips in the upper buffer shorted, should I change only those I do not want to blow up my new buffer
            tks
            • panson
              • Mar 2012
              • 20
              • usa
              anyone have the price and part numbers on the buffers for samsung hpt5054 ?
              • tw2005
                • Oct 2011
                • 6458
                Buffer ICs or buffer boards?
                You have the numbers in front of you on the board.
                LJ92-01401A,LJ92-01491A, are some
                http://www.shopjimmy.com/samsung-996...repair-kit.htm
                Common failure is shorted ymain and shorted upper buffer
                you may find repair services for both
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  My video little info on this set:
                  https://m.youtube.com/watch?v=57aDWsiLIxE
                  Tom66 alot of info:
                  https://m.youtube.com/watch?v=25HTy6esBHs
                  • mmartell
                    • Oct 2013
                    • 3189
                    It must be said somewhere between those videos but after ysus repair install it without the buffers and make sure the green led is NOT lit. Otherwise you still have a problem and if the buffers had been installed it could pop them.
                    • panson
                      • Mar 2012
                      • 20
                      • usa
                      Good advice I was thinking that is the way to do it. I ll do it. tks Lord Martell
                      • panson
                        • Mar 2012
                        • 20
                        • usa
                        I want to practice replacing those chips TKS
                        • panson
                          • Mar 2012
                          • 20
                          • usa
                          I would like to thank you so much to all the techs helping me on this one
                          Samsung 996510011737 Buffer Component Repair Kit (LJ92-01491A / LJ92-01492A)
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • LEECH666
                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                            by LEECH666
                            Good day ladies and gentleman!
                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                            01-19-2024, 05:46 PM
                          • KYBOSH
                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                            by KYBOSH
                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                            No picture but you hear the TV static (white noise) playing loud and clear.
                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                            But it seems they didn't get too far and just left it.
                            When I first took a look I was amazed at how pristine the inside looked.
                            Its as if the TV had been in a time capsule.
                            Caps looked like they were just pulled off the self.
                            Copper coils had no sign of corrosion on...
                            02-01-2023, 11:10 PM
                          • SluggerB
                            LG Plasma (PDP50R10101) No picture No sound
                            by SluggerB
                            This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
                            So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
                            Following a YouTube videos...
                            12-03-2022, 09:10 PM
                          • Christos Tsiligiannis
                            Marian Trace Alpha sound card repair help
                            by Christos Tsiligiannis
                            Hello to the forum.
                            My name is Christos, I am new to the forum here and i am posting from Greece.
                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                            11-18-2024, 05:26 AM
