Samsung LE40C530F1W Sound No Screen
  • Glowstone
    • Jun 2016
    • 16
    • United Kingdom
    Hi all..
    (I bet the TV techs get sick of this kind of thing)
    I have the above LCD TV and there is no screen. The start up chime plays fine though.
    I have replaced 11 main caps on the power board and checked both glass fuses that check out fine.
    Any thoughts on what I can test next?....could it be the lighting controller/ circuitry is dead?...what sort of money are those?
    many thanks
    Martyn
  • Glowstone
    • Jun 2016
    • 16
    • United Kingdom
    Re: Samsung LE40C530F1W Sound No Screen
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Read some of the other threads on this set ?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        When you look at the back do the tubes light up which you should see through the holes in the rear chassis.
        With a strong light and after the chimes press menu and scan the screen to see if you can see the menu being displayed on the panel in the background. You have to move the light around the screen and look carefully.
        If you have a menu next plug a dvd player into the scart socket since these usually do not need you to select in the menu and see if you have sound when you play a disc.
        If all those work then you have a backlight problem.
        If none of the above work then take all the voltage readings you can and report them back.
        EG
        Con1
        Pin 1 (label) standby voltage) Out of standby
        Pin1 (+5V) 0V +5V
        etc
        • Glowstone
          • Jun 2016
          • 16
          • United Kingdom
          Many thanks..
          I have tried to force start the backlights by removing pin 6 on the top row of the 18 pin connector to the logic board..nothing happened.
          I just looked to see if I could see any dim images or glows to the side and there isnt anything there.
          I am unsure where to start testing pinouts?
          Thanks again!
          • CapLeaker
            Leaking Member
            • 8148
            2nd picture left side. We need all voltages on the connector with the corresponding pin out name, tv on and tv off.
            • Glowstone
              • Jun 2016
              • 16
              • United Kingdom
              Sorry for the late reply...
              here are my readings
              Pin STDBY-v ON-v
              1. 0.00 12.89
              2. 0.00 0.47
              3. 0.00 12.89
              4. 0.00 2.85
              5. 0.00 12.89
              6. 0.00 1.29
              7. GND
              8. 0.00 1.75
              9. GND
              10. GDN
              11. 0.00 5.25
              12. GND
              13. 0.00 5.25
              14. 0.00 5.25
              15. 0.00 12.90
              16. 5.25 5.26
              17. 0.00 12.89
              18. 3.00 3.96
              I accidentally hit the chassis with my needles and the TV seemed to restart..I am guessin thats a protect function....
              many thanks for your time!
                Pin STDBY-v ON-v
                1. 0.00 12.89
                2. 0.00 0.47
                3. 0.00 12.89
                4. 0.00 2.85
                5. 0.00 12.89
                6. 0.00 1.29
                7. GND
                8. 0.00 1.75
                9. GND
                10. GDN
                11. 0.00 5.25
                12. GND
                13. 0.00 5.25
                14. 0.00 5.25
                15. 0.00 12.90
                16. 5.25 5.26
                17. 0.00 12.89
                18. 3.00 3.96
                Where are the pin names so we can tell what the Voltage readings are for.
                • Glowstone
                  • Jun 2016
                  • 16
                  • United Kingdom
                  Sorry
                  Name Pin on off
                  B13V 1. 0.00 12.89
                  5V DET 2. 0.00 0.47
                  B13V 3. 0.00 12.89
                  BLUON 4. 0.00 2.85
                  B13V 5. 0.00 12.89
                  EPWN 6. 0.00 1.29
                  7. GND
                  HSYNC 8. 0.00 1.75
                  9. GND
                  10. GDN
                  B5V 11. 0.00 5.25
                  12. GND
                  B5V 13. 0.00 5.25
                  B5V 14. 0.00 5.25
                  B13V 15. 0.00 12.90
                  A5V 16. 5.25 5.26
                  B13V 17. 0.00 12.89
                  PS-0N 18. 3.00 3.96
                  Many thanks
                    BN44-00340B diagram.
                    https://www.badcaps.net/forum/showth...ht=BN44-00340B
                    So are you getting close to 400VDC between the two legs of the main filter cap?
                    • Glowstone
                      • Jun 2016
                      • 16
                      • United Kingdom
                      Thanks budm
                      I am a novice to this as you can guess..
                      which one specifically would be the filter cap?...there are 2 large yellow caps here as in the other posts.
                      What is the safest way to test these for the voltages you mention?
                        Pictures provided by shopjimmy.
                        You can choose either one of the two large yellow caps.
                        • Glowstone
                          • Jun 2016
                          • 16
                          • United Kingdom
                          329v standby
                          325v power on
                          I take it thats not a good look!
                          • Glowstone
                            • Jun 2016
                            • 16
                            • United Kingdom
                            Ok I have also tested diode DP801 and in Diode test mode it reads 519 when negative to negative and infinity when reversed....
                            DP805 reads 527 negative negative and infinity when reversed
                              DP801, 805 are right next to each other.
                              https://www.badcaps.net/forum/attach...2&d=1466630101
                                BTW, you should show the straight shot pictures of the whole power supply board that I can read the part designators, the one from SJ is Revision 1.2, yours is 1.1
                                • Glowstone
                                  • Jun 2016
                                  • 16
                                  • United Kingdom
                                  yes I just spotted that..its been a long day here sorry about that
                                  heres a front pic..did you want a closer shot of anything or of the back also?
                                  many thanks
                                    As long as those two DIODES are not shorted then they are OK, if they are shorted then you will not get the 400VDC boosted Voltage.
                                    So now you need to check if the PFC IC to find out if it has DCV between VCC and GND pin when PS-ON is present.
                                    • Glowstone
                                      • Jun 2016
                                      • 16
                                      • United Kingdom
                                      I think the diodes are ok..
                                      so I need to bring the supply out of "stand by"... and test the ground pin of CN802 with black probe...and the collection of power with the red probe...
                                      which is the best point to test the collection...would that be at the diodes anode?
                                        you are making the measurement in the HOT DEADLY side of the circuit, the GND is the negative leg of the main filter cap.
                                        You need to locate the PFC Controller IC to find out which one is the VCC pin, see schematic for details.
                                        The IC is SMD and mounted on the bottom side of the board so it is not going to be easy checking the Voltage during live test.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • mrtek
                                          Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                          by mrtek
                                          Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                          11-26-2024, 09:58 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • mar1in
                                          Samsung TU8000, backlight and sound on, stuck in blue screen
                                          by mar1in
                                          I've got this Samsung here that would be stuck in a boot loop.
                                          After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                          Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                          Thanks in advance
                                          11-08-2023, 05:43 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
