Hi I'm new to the forum.
I have a Panasonic TCP50S30 that has the 7 blink problem.
Previously I had a failure on the SU board and had a driver chip replaced by someone on eBay. SC board was okay and the repaired board worked for around 6 months and then I got the 7 blinks again. When the SU board failed previously, I had a direct short from the panel ribbon cable connectors to chassis ground and I was able to trace it back to the affected driver IC. So I knew which board failed.
This time I have no shorts from the SU nor SD ribbon cable connector pins to GND. The SC board failed (loud pop and IC 784 pin 5 blown off board), I had the SC repaired from the same guy. Plugged in repaired SC board, pow SC board failed again. D642,Q622,Q623,D643,Q661 all shorted, again IC784 cracked by pin5 carbon sprayed around there. The IGBTs are shorted from G-C-E and the diodes are shorted 1-2, 2-3. Okay, don't have time to fix right now. Purchased a 2nd (working) SC board off eBay for a good price.
I run the isolation test using 2nd SC board by disconnecting the SU and SD boards at connectors SC41, SC42 and SC46, unplug SU11 from SD11, removing the 4 VF screws on the driver boards and with the jumper on SC50. The SC board has the green LED on and I hear buzzing going on, so I think this is good. I connect the 2nd SC board with the SU and SD and go for broke, but I get the 7 blinks, at least no smoke with this SC board. So I must have a bad SU or SD board correct?
So my question is how do I diagnose the SU or SD boards if they have no shorts from the ribbon connectors to GND. I don't really want to connect one or the other SU or SD board to the SC and push my luck and try it again, I don't want to run the risk of blowing up the 2nd SC board. Are there any other weak points on these boards I can check for failures?
Checked resistance from SU SD ribbon connector pins (black lead) to VF (red lead). Set to diode check, I get a nominal .778 on all pins.
Checked resistance on all pins SC41 to VF and SC42 to VF, get infinite on 20Kohms range.
Really love the picture on this plasma set when it is working.
Thanks in advance
Kurt
Thanks in advance
Kurt
