Quadro TV 17mb22-2 no picture, backlight ok
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hello, i have a Quadro TV set with no picture, but sound and backlight are okay. Tv starts normally, you can hear speakers initiate and after 2-3 seconds backlight comes on.
    Mainboard 17mb22-2
    PSU 17pw20
    Tested the panel and backlight with spare mb and psu and the panel produces picture, also inverter seems okay. Voltages on PSU are okay, 24v=24.3, 12v=11.9V etc.
    I did measure most of the voltages on MB voltage regulators and it all seems okay, 3.3 is 3.3, 12 is 12, 1.8 is 1.8. The only problem i have found is on LVDS connector (PL406) on mainboard and few voltages are missing, anyone had problems like that?
    Most interesting are Pin27 5V (but it looks it should be 0V)
    Pin1,3,5,7 0V
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Quadro TV 17mb22-2 no picture, backlight ok
    Ok so with a different Mb it produces image ? Also Vestel schematics are ALL DIFFERENT so on one board the Lvds might be 5v on another it might be 8v so thats probably normal they build the board to the screen used in the set.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      I wonder if you have corrupt firmware. I see in previous threads for the main board that the eeprom can be replaced with a blank one. Maybe someone can confirm whether this is true or not and worth trying.
      • 6ot4hr
        • Oct 2014
        • 87
        • Croatia
        I had a corupted eeprom on the working set which i used to test this set, basically it was just producing red, green, blue screen on the set (but i replaced it).
        I did try to put Eeprom from the 17mb12 onto this 12mb22 but no change - still no picture. Eeprom did survive the switching.
        If i remove eeprom from this broken set, it doesn't turn on at all nor it reacts to any keypresses from the remote or keypad.
        • victor_cj
          • May 2015
          • 90
          • Romania
          https://www.xfile.ro/gYz03by&p=AbWnjMfh4xGRBzN
          17MB22-2 24C64 MEDION MD30272ATA.BIN
          17MB22-2 24C64 MYRIA MY26735BK.BIN
          17MB22-2 24C64 TELETECH 32715.BIN
          17MB22-2 32inc 24C64WP.BIN
          The art of fighting without fighting
          • 6ot4hr
            • Oct 2014
            • 87
            • Croatia
            Thnks Victor, will try to reflash the eeprom. Will inform you back, cheers!
            • 6ot4hr
              • Oct 2014
              • 87
              • Croatia
              Final thoughts: TV repaired, panel_vcc was around 5V while on working mb was 12V. Forced 12V to panel_vcc and it works.
              Thank you all for your help!
              • robert1000
                • Aug 2015
                • 4
                How did you change the mainboard panel voltage ? which modifications yoi had to do? I'm in the same boat now and need help.
                thanks alot!
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • groomit
                  Philips 50PUS7363/12 Backlight but no picture
                  by groomit
                  I'm having trouble with above mentioned TV. Bought it defect.
                  Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                  Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                  I can see backlight, but screen stays black.
                  What I've tried:
                  - Disconnect right side cable from T-Con -> same (backlight but no pic)
                  - Disconnect left side...
                  11-22-2024, 02:43 PM
