Anyone used one of these LED Backlight testers?
  • cliff_hootarski
    • Jul 2006
    • 411
    http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
    Look interesting.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Anyone used one of these LED Backlight testers?
    There's been some discussion on them lately. If you're repairing sets regularly then I think they would be a useful addition to the tool box for quickly diagnosing led strings without having to strip down the panels..
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      A friend of mine Simon does and he says they are great.
      • cliff_hootarski
        • Jul 2006
        • 411
        Bought one, will be testing soon. Will let everyone know the results.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Funnily enough, I've just ordered one also. It was considerably cheaper than when I last looked at it, in fact half the price so my order has gone in.
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • canadaboy25
            LG Flatron 24EN33TA No Backlight When Cold
            by canadaboy25
            I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
            I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
            03-07-2023, 12:23 AM
