LG PZ550 moving Vertical lines (video inside)
  • alxx
    • Jun 2016
    • 6
    Hey Guys,
    I need some help with my TV.
    As you can see in the Video I have some vertical lines.
    Is this problem fixable?
    https://youtu.be/eEI9CY6_z2w
    I already tried swapping out the tcon board, didnt fix the problem.
    Next thing I'll try is swapping out the mainboard.
    Maybe you have some more suggestions.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG PZ550 moving Vertical lines (video inside)
    I think you may have the same problem as in this thread
    https://www.badcaps.net/forum/showthread.php?t=54942
    • alxx
      • Jun 2016
      • 6
      Yes it looks similar.
      So swapping out the Mainboard wont help?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        No panel fault. Dont spend a penny on it.
        • alxx
          • Jun 2016
          • 6
          So maybe I'll try the heating method.
          Wich part exactly should I start with?
          Is it that long board with the chips on it behind the metal cover?
          • yoritomo
            • Sep 2012
            • 155
            • Belgium
            Sorry to confirm, this is a panel fail which can't be fixed, can see junk random pixels on this line, then no way it would be coming from the panel ribbons.
            It has many thunders in Europe lately with this terrible spring, just wait someone has a dead set to be lucky to have spare panel. (like a vulture waiting on a branch )
            Other brand and models of TV often shares the same panel, often AUO and Samsung panel in LG European models.
            • alxx
              • Jun 2016
              • 6
              Well too bad, thanks anyway.
              • Stanley1843
                by Stanley1843
                06-29-2024, 11:54 AM
              • pni
                LG 49uf695v vertical coloured lines
                by pni
                Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                11-14-2025, 03:15 AM
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
              • gpo23
                Sony KDL-40V3000 - Vertical lines
                by gpo23
                i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                With the new t-con the color are good but there are vertical lines on all the screen :
                I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                Is there a way to fix the vertical lines on the new t-con ?
                Thank you for your help
                gpo23...
                10-04-2023, 09:11 AM
              • Firentiosi
                1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                by Firentiosi
                Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                The issues are as follows: the...
                11-27-2024, 12:33 AM
