Sony KDL 42W705 backlight no sound, no picture
  • sansiro2
    • May 2016
    • 18
    • United Kingdom
    Hi guys, got a Sony 42W705 LED TV. Only get backlight but no picture. I get a one second blast of sound when I switch the TV on but then silence. I have changed the T Con and the main logic board to no avail. If I pull the LDVS off or the power cable to the main board while TV is on nothing happens.
    By the way for the T Con I matched the TX-5542T35C01 bit of the barcode, although the rest is slightly different.
    Any ideas what could be the cause?
    Re: Sony KDL 42W705 backlight no sound, no picture
    Pictures of the whole back side of the TV so we can see all the boards?
    • sansiro2
      • May 2016
      • 18
      • United Kingdom
      1st pic Power board with cover taken off
      2nd pic main board
      3rd secondary av board which clips on to main board
      The t con is underneath the secondary av board
        I expect to see the FRC (Frame Rate Conversion) board between the main board and the T-CON board, it does not look like it has one.
        Did you check the DCV on both ends of the SMD fuse with ref to the chassis to see if the T-CON is getting the 12VDC? It is not going to be easy due to the location of the T-CON board.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Have you checked F101 on the Tcon. Recently received a Tcon where the fuse was blown.
          • sansiro2
            • May 2016
            • 18
            • United Kingdom
            F101 appears to be fine. It's going to be awkward but where would I put the test probes to test if 12v is coming in? I assume tv needs to be switched on. Apologies been a since I done any electronics
              Black probe on the chassis Gnd, red probe on the fuse's ends (check DCV at both ends), TV has to be ON.
              • sansiro2
                • May 2016
                • 18
                • United Kingdom
                Thanks I'll try to find a way to do this given the awkward positioning and let you know. Thanks
                • nanias
                  • Aug 2016
                  • 6
                  • Portugal
                  Can you tell us the result?
                  I have the same problem.
                  Any one can help with a solution for this sintomes?
                  • nanias
                    • Aug 2016
                    • 6
                    • Portugal
                    Please, If someone can help I appreciate because Sony is make me crazy...
                    I have already change the cable (and nothing change so that was not the problem):
                    SONY KDL-42W705B LVDS CABLE 1-848-110-11
                    This are the Symptoms in na attached video:
                    https://drive.google.com/open?id=0B_...UtEZklmYUliZzA
                    Can it be T-Con?
                    Thank you
                    Antunes
                    Lisbon-Portugal
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Hi Nanias, what have you tested so far ? I also have the same set with a blown up Tcon I will diagnose it soon. Shame the guy NEVER BOTHERED to update the thread.
                      • nanias
                        • Aug 2016
                        • 6
                        • Portugal
                        In fact I dind't check nothing else because i am only a curious guy.
                        I read that could be a problem with the cable LVDS and I start there
                        Because the T-Com is more expensive i was trying by parts.
                        My afraid is that the problem can be the LCD panel. That's why I show the Symptoms to see if someone can help because i found a lot of people with the same problem.
                        Thks
                        • sansiro2
                          • May 2016
                          • 18
                          • United Kingdom
                          Sorry guys I didn't get an email notification. But diagnosis was short circuited panel so TV is a goner. Shame on Sony, used to a brand you could rely on.
                          • nanias
                            • Aug 2016
                            • 6
                            • Portugal
                            Thanks sansiro2.
                            I made some more tests. I unplug one of the cables of T-Com and the result was this in the photo. No image. I do the same on the other cable and the result was the same. No image in none of the sides.
                            Any help?
                            • sansiro2
                              • May 2016
                              • 18
                              • United Kingdom
                              Sorry I have no idea. Maybe the technical guys can help.
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                That looks like a bad t-con or bad panel! You need to measure the voltages as described above!
                                The T-con had a small fuse ( usually ) next to the LVDS port. Its very small and says something like "F101". Measure for continuity and measure the voltage.
                                • nanias
                                  • Aug 2016
                                  • 6
                                  • Portugal
                                  Hi Moreno83,
                                  Thank you so much. I will do that.
                                  My doubt is exactly that: T-con or bad panel. How can I be shure? Because if it is the panel everyone said to forget this TV and buy a new one. I will buy a T-con if I have the certainiity that this is the problem. I must import the T-Con and it will cost me about 50€ (used).
                                  Can you please tell me a test or a trick to eliminate this doubt? For exemple, if the fuse is ok can I assume that the problem is the panel?
                                  Can someone confirm that I have understand correct the possition of the probe of the multimeter? (I attach a picture).
                                  For someone who be interested i alsso attached a picture of the back of the TV.
                                  Thank you so much for everyone who can help.
                                  Nanias
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Screw your tcon board back down. Black lead on chassis. Red lead on one side of the fuse and read dc voltage, then red lead on other side of fuse and read dc voltage and the readings should be identical.
                                    • nanias
                                      • Aug 2016
                                      • 6
                                      • Portugal
                                      Originally posted by dick_barton
                                      ...the readings should be identical.
                                      If they are identical, can I assume the problem i have mencioned is on the LCD panel or that is nor conclusive and the problem can be at the T-Con but on other part (not the fuse).
                                      Forgive me the questions but I will open the TV and I would like to be conclusive at that time to see everything when the tv is open. Furthermore english is not my language and sometimes I don't understand words (i use Google translation...).
                                      Thanks again
                                      • KEHT
                                        • Apr 2016
                                        • 4
                                        • Ukraine
                                        Yep, unscrew metal shields from the bottom of the LCD. Something like this.
                                        http://www.imagebam.com/image/219837503058597
                                        Check burned routes on the flexible cables. Something like this.
                                        http://www.imagebam.com/image/913b54503058762
                                        Congratulations, you got a s/c in your LCD. Yes, its time to buy a new TV
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
