Philips DVDR3460/75
  • Amraks
    • Nov 2011
    • 725
    Philips DVDR3460/75
    Hi Guys I am Working on a DVDR there is no standby light.
    Started from the obvious first.
    PSU Fuse = All Good
    Bridge = All Good
    Checked Voltages
    1 12V_STBY = 13
    2 GND_D
    3 5_STBY = 5
    4 3V3_STB = 3
    1 VGN_STBY = 5
    2 5N_STBY = 5
    3 GND_A
    4 IPFAIL = 5?
    5 GND_A
    6 12VA_STBY = 13
    What could this be?
    So far I have replaced these caps on the analogue board just on a hunch that these might be bad not sure if I should go ahead and replace the rest in this area.
    2121
    2151
    2118
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Philips DVDR3460/75
    IPFAIL"-signal from power-supply-unit to kill the audio outputs can be
    killed
    • Amraks
      • Nov 2011
      • 725
      Can you explain that in some more detail not understanding what you mean?
      • Amraks
        • Nov 2011
        • 725
        I found what you meant
        ("D_IKLL"-line) or the "IPFAIL"-signal from power-supply-unit
        (in this case it's the combination of "A_KILL" and "IPFAIL").
        In addition to that the DAC [7001] and the cinch outputs can be
        killed (muted) in case of "digital silence" by the circuit around
        [7008], [7009] and [7010], when no audio data are available
        (e.g. "D_DATA0"-line zero).
        This function can be also activated via the "ION"-line (set to
        high during any stand-by mode). To avoid signal distortions
        (clipping) the mute transistors for cinch rear out [7415], [7416]
        are decoupled via [7011].
        I just guess its killed all all audio inputs as nothing is hooked up.
        • Amraks
          • Nov 2011
          • 725
          Just thought I would redo my voltages
          1 VGN_STBY = -25.73v
          2 5N_STBY = -5.305v
          3 GND_A = -4mv
          4 IPFAIL = 5.180v
          5 GND_A = 7.1mv
          6 12VA_STBY = 13.20v
          Checked Voltages
          1 12V_STBY = 13.19v
          2 GND_D = -0.7mv
          3 5_STBY = 5.182v
          4 3V3_STB = 3.494v
          5 GND_D = -0.6mv
          Thoughts?
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
          • double_DD
            Philips curling iron - is this a common AC cable?
            by double_DD
            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
            08-18-2025, 10:04 AM
          • janos6662000
            Philips 47PFS7509/12 LCD TV problem
            by janos6662000
            Hi
            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
            When i applied cable signal to check image, i had normal picture, but TV was restarting.
            I downloaded original firmware and applied the update, but the problem remained.
            From a colleague i received a "factory package software" which is a lot bigger.
            I made another firmware update, but still did not solve the problem.
            Somewhere on the way the error got worse, because at the moment the...
            08-12-2025, 12:54 PM
          • aidanmo
            Philips 43PUS7506/12 - Loud blown out sound
            by aidanmo
            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
            I thought maybe the speakers got damaged, so I replaced them - no dice.
            • Using the internal speakers, it always happens.
            • Using the headphone jack, it never happens.
            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
            02-28-2025, 03:13 PM
