Samsung LED Model #un55hu8530 picture but no sound
  • pr0ject
    • Nov 2013
    • 26
    • usa
    While I am watching TV the sound cuts out. I can reset it and unplug it or just wait and sometimes the sound comes back, but not consistently.
    Sometimes when I run the self diagnosis on sound the sound is static-y.
    Any ideas appreciated. I ran through the samsung technical help hotline and they had me do the usual reset/turn off and on etc with no change in result. Although everything they did was what I did already.
    I suspect there is a part that needs to be replaced. Sometimes, when the sound cuts out the tuner becomes really slow... I suspect it was the recent firmware upgrade to 1152 when this issue started but obviously no way to prove it.
  • pr0ject
    • Nov 2013
    • 26
    • usa
    Re: Samsung LED Model #un55hu8530 picture but no sound
    I also wanted to add that I can hit the menu or volume buttons and hear the clicky sound, just no sound from the programming. Whether in attenna or with HDMI device or with Smart HUB apps.
      'un55hu8530' Is that really the correct model number? Does it have audio line out jacks that you can test to see if you get the sound there?
      • pr0ject
        • Nov 2013
        • 26
        • usa
        Re: Samsung LED Model #UN55HU6830picture but no sound
        http://www.samsung.com/us/support/ow...UN55HU6830FXZA
        That's the tv.
        i messed up the model #
        UN55HU6830
        • pr0ject
          • Nov 2013
          • 26
          • usa
          Yes tried the audio jacks I can get the volume/menu clicks to come out of a sound bar, but the audio of the programming/netflix etc does not come out. I think the board with the audio processor on it is fried? Anyone know which board that is?
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • Dodgethis
            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
            by Dodgethis
            Hello all,
            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
            09-11-2024, 07:39 AM
          • marekk
            Samsung QE55Q67RAT no sound and bad picture when streaming
            by marekk
            I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
            I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
            Mainboard is based on pcb BN41-02695A BN94-14007B
            I will appreciate any help
            Many thanks
            Marek...
            05-29-2025, 02:23 AM
