Parts: What do you keep on hand?
  • JDC
    • May 2015
    • 273
    I'm looking into building a repair kit to keep on hand while learning how to troubleshoot TV issues. So far, the 20 or so 1000uF 35v caps I bought have come in handy, but what about diodes and MOSFETs? What do you suggest I should have on hand?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Parts: What do you keep on hand?
    I have a tonne of shit, all ordered though in bags from what I had previously used for repairs also a load of caps with common values. In my other bags got mosfets, diodes, leds, resistors everything. Then a lot of Tv boards.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      I just order a few extra components each time so a stock builds up. Plus a number of unrepairable circuit boards at hand.
      • vinceroger69
        • Mar 2012
        • 6714
        This is what i have been doing too ive also been collecting free smashed screen sets as the boards/led strips are always worth having.
        • JDC
          • May 2015
          • 273
          What are some common values of diodes and MOSFETs that I should keep on hand?
            • 31296
            uf4007's are handy
            and mbr5200 - but hard to find.
            • CapLeaker
              Leaking Member
              • 8352
              I am doing the same thing.
              • jetadm123
                • 2169
                It's probably unrealistic to stock any common value of mosfets, since each manufacturer has their own supplier(s) and there are a LOT of suppliers. Therefore, there are many different part numbers used. If you've had a chance to look at power supply schematics, you would see that many of the mosfets used are not used on any other supply. It's almost like the manufacturer's go out of their way to use a new part number every time they design a new supply.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  The variety of parts does make it difficult to know what to stock and holding stock can be expensive.
                  I ordered Mosfets for a Samsung Ysus set the other day from Italy and received them in 36 hours. Better than our First Class local postal service.
                  • JDC
                    • May 2015
                    • 273
                    I figured that. I was looking on eBay for diode variety kits and was looking into getting one but I wasn't sure what to get.
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      1/4 watt resistors of every imaginable value, 1000uf 470uf 2200uf caps in 25v and 35v, zener diode kits in 1/4 watt, 1/2 watt and 1 watt, 1n4148 diodes, 1n4007 diodes, fuses in several values. Then when I order parts for a specific set I usually order several extras of each thing. Some models have the same failures on every set (like the 98$ emerson from walmart) I usually get enough to fix 5 before I have to reorder parts. Plus something on the order of 100 broken screen sets i have accumulated.
                      Liberating magic smoke one part at a time
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        It is okay to look at ebay auctions to get a clue/hint of what the repair kits includes as it might point out the most often failed part, but since you live in the USA, I suggest avoiding ebay for your parts as they are likely to be counterfeit or questionable quality.
                        I would also take the feedback left for sellers with a huge grain of salt. Most DIY people can't tell the difference between a fake and genuine and most don't know the difference between a general purpose cap and low ESR cap.
                        You have reasonable shipping costs with reputable distributors like digikey and mouser and usually get the parts in 48 hours, just to name two.
                        --- begin sig file ---
                        --- end sig file ---
                        • Hamie
                          • Apr 2014
                          • 1383
                          13N50 are something I use a lot of.
                          Used in loads of samsung and VESTEL power supplies.
                          Also a handy sub for 9n50 and 11n50.
                            • 31296
                            you dont need 250ma zeners, 500ma will fit inplace of them - the package is the same size.
                            and you should skip the in4007's and use uf4007's instead.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Dont forget UF5402's, UF5404's and SB5100's for the Vestels lol
                                • 31296
                                or just uf5408's and sb5200's
                                • Dvsr
                                  On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                  by Dvsr
                                  Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                  I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                  After replacing the caps I started testing out the speaker. It seemed...
                                  09-10-2025, 10:20 AM
                                • caspian
                                  What Zener Diodes on a Linear Power Supply
                                  by caspian
                                  Dear members,
                                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                  In addition, I discovered that its zener diodes are defective.
                                  I can replace the burned transistors.
                                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                  Therefore, I cannot replace the zener diodes.
                                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                                  no schematics are available...
                                  05-26-2025, 12:38 PM
                                • Sisko
                                  Onkyo-593 No power and now clicking sound
                                  by Sisko
                                  Hi all!!
                                  Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                  10-03-2025, 02:18 PM
                                • Mark D
                                  Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                  by Mark D
                                  The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                  10-29-2024, 03:15 PM
                                • Dannyx
                                  UC3842 Power Adapter Blowing Fuse
                                  by Dannyx
                                  Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                  Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                  12-05-2023, 12:06 PM
