Sunbrite 3200hd-pro
  • White fish
    • Jun 2016
    • 9
    Sunbrite 3200hd-pro
    Hello I was given a outdoor tv
    I am not a tech so my skills a limited but not afraid
    If I see something obvious (bad cap I can solder an new one in) or can change a board but testing skills are lacking
    hooked up AV1, AV2 and VGA all seem to be in black and white
    when switching, blue screen looks fine
    the on screen menu looks fine
    I pull out the input board sprayed with contact cleaner
    pulled out the cable going from main board to t-con board sprayed with contact cleane
    can we go through the list...
    color on the menu is fine, blue screen looks fine - So I think the panel is OK
    no lines or bloshes - So I think the Tcon board is fine
    the screen is lite up and menu looks fine - So I think the back light board is fine (however I do hear a little hum coming from that but maybe that is there all the time when its on??)
    so Im left with main board or input board
    this is a very old tv but an outdoor tv should I throw money/parts at it or cut my losses
  • White fish
    • Jun 2016
    • 9
    Re: Sunbrite 3200hd-pro
    this tv shares boards from what looks like some OLEVIA or SYNTAX tv's
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      "A picture is worth a thousand words". If you can post pictures and also of the circuit boards would be a good start looking for help.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        That was fast. Can you also supply a screen shot please.
        • White fish
          • Jun 2016
          • 9
          • White fish
            • Jun 2016
            • 9
            another strange part it wont let me change
            Brightness, Contrast, Saturaton, Hue or Sharpness by more then 1 or 2 points
            • Diah
              • Feb 2013
              • 6589
              it is the main boards issue, much like leads soldering open. or main chips processor issue, try with finger on the black heat sink push down little hard many time if the screen make color effect
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Have you tried different video sources?
                Permanently Retired Systems:
                Kooky and Kool Systems
                sigpic
                • White fish
                  • Jun 2016
                  • 9
                  I have feed it with VGA (computer)
                  AV 1 (composite input yellow red white) WD media player
                  and AV 2 same
                  I dont have anything component input (RBG)
                  I have tried the WD media player with the same cable on different tv and works fine
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Have you set the TV to the wrong standard. NTSC, PAL SECOM etc. That's the only time I can remember seeing a colour picture turn B/W especially since you have the menu in colour.
                    Is there a Reset to Factory mode buried in the menu?
                    Edit:
                    If you tried it through AV1 & 2 that bypasses the tuner so I doubt its a standards selection problem as I first thought.
                    • White fish
                      • Jun 2016
                      • 9
                      Ok
                      I tried wiggling the black heatsink - no change
                      I pulled the board and tried the heatgun on the backside of the board - no change
                      so are we are pretty confident that its the main board?
                      thanks
                      • Diah
                        • Feb 2013
                        • 6589
                        from this i think its main boards, and only the main processor which under the heat sink responsible for this adjustment and video out put.
                        try to go to Sunbrite website and download the Firmware and play it again.. it may help too
                        • White fish
                          • Jun 2016
                          • 9
                          I cant find anything about this tv on their website
                          Im looking for anything, doesn't seem to be very much no firmware no hidden menu
                          thanks
                          I will order a new board from Jim
                          • White fish
                            • Jun 2016
                            • 9
                            Got my new main board today
                            worked like a charm
                            now I just have a bit of "burn in" Im tryng to get rid of
                            Thank you guys so much for your help
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                              After all of...
                              07-13-2024, 08:14 PM
