i have this sony tv nsx-40gt1 i replace the main board, and now it does turn on. before i did change this board it didnt power on just red blinking ligth. now that it works back light comes on, but no picture. this tv has 3 boards one with the tuner, i replace and the others are for internet and t-con
SONY TV NSX-40GT1 no picture/ only back ligth
Re: SONY TV NSX-40GT1 no picture/ only back ligth
when i turn on the TV back light comes on and the after a sec it blinks green and orange it has 3 led light and those 2 only blink green and orange at the same time. green is power and the orange is it timer picture offComment
That board in the middle is the Tcon board. Make sure the fuse on the TCon is good and there is power going to it. You can verify the signals on the LVDS with an oscilloscope, whilst turning on and off the menu all the time and probing the LVDS pins.
Also we need voltage measurements of the PSU (ribbon cable that goes to the main board) with the TV on and off, to see what is really happening.Comment
There are 3-pin Voltage regulators such as IC5, ICR4 which has Voltage test points next to them telling you what the DCV should be, there are also other DCV test points on the boards as well, such as VCOMS1, 2, VGMAxx, VDD3.3, etc. so look at the board really well.
Sony 1-857-792-11 (TSL_C2LV0.2) T-Con Board for NSX-40GT1
http://www.shopjimmy.com/sony-1-857-...-con-board.htm
Picture provided by shopjimmy.
BTW, 12VDC at both ends of the fuse with ref to GND?Attached Filesif you find these attachements useful please consider making a small donation to the site
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by koby058Hi people!!
The owner said it showed bad picture once in a while (attached)
I see that there is back light but no picture.
I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
Also attached schematic and BDV
LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590... -
by iglitareHi,
Or is it always a bad/shorted... -
by tree5656This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
by DKWS89Hey Guys,
So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons... - Loading...
