Samsung 60" LED Issue (UN60H6400AFXZA)
  • cheapshot
    • Jul 2012
    • 41
    • Bahamas
    Hello everyone. I have a Samsung 60" LED TV Model #-UN60H6400AFXZA. Here is the issue: TV will cut on fine, standby led is fine. No image at all though and no backlights seen at all when TV is cut on. Sound works as well, I can hear when I toggle the menu options it is responding. I have attached some images so hope this helps as I have done no troubleshooting yet. I will test the main filter cap and get back as I need help testing the led output. Thanks for you help here!
  • cheapshot
    • Jul 2012
    • 41
    • Bahamas
    Re: Samsung 60" LED Issue (UN60H6400AFXZA)
    I see www.shopjimmy.com sells the complete board kit for this here: http://www.shopjimmy.com/samsung-un6...-version-1.htm
    You think its worth getting or we should rule out the LED strips first?
      Do you get the baklights when you power up the power supply/LED driver board without the cable connected to the main board?
      • cheapshot
        • Jul 2012
        • 41
        • Bahamas
        Budm, let me check that sorry. Sorry for the long delay!
        • cheapshot
          • Jul 2012
          • 41
          • Bahamas
          Yes sir. Backlights work once main board is disconnected. Main board issue?
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            Sounds like something is loading down the PSU enough to knock out the backlights. Try reconnecting the mainboard and retesting.
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
            • cheapshot
              • Jul 2012
              • 41
              • Bahamas
              Reconnected mainboard same issue as before. No backlights.
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Ok
                sigpic
                • cheapshot
                  • Jul 2012
                  • 41
                  • Bahamas
                  So seems like a main board is in order or is more testing needed with this?
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    Let me obtain some schematics for this TV...
                    sigpic
                      That means the main board is not sending the BL-ON (BLU-ON) to turn on the backlights circuit.
                      Try disconnecting the T-CON board, heat and cool the main board to see if it has any affect.
                      • cheapshot
                        • Jul 2012
                        • 41
                        • Bahamas
                        No effect Budm.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Common issue is the Spi Flash Ic which contains the firmware corrupting and not turning the set on. If you can source a chip with the firmware on replace it if not replace the motherboard
                          • cheapshot
                            • Jul 2012
                            • 41
                            • Bahamas
                            Thanks guys for all your help. I will source the MB with kit mentioned earlier. I will get back with results thanks!
                              09-07-2024, 05:50 AM
                            • vincentedel
                              Samsung SyncMaster 740n Phase Control Issue
                              by vincentedel
                              I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                              I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                              04-22-2025, 12:33 AM
                            • Manucsl
                              QE65Q800TATXXC Samsung TV Issue
                              by Manucsl
                              Hello.
                              My TV is a QE65Q800TATXXC Samsung TV.
                              Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                              Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                              Any ideas to check would be very appreciated 😊
                              After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                              02-19-2025, 07:47 AM
                            • FourRunner
                              Display issue Samsung TV UA65JS9000W
                              by FourRunner
                              I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                              10-03-2024, 07:05 PM
                              09-06-2024, 11:40 PM
