Hello everyone. I have a Samsung 60" LED TV Model #-UN60H6400AFXZA. Here is the issue: TV will cut on fine, standby led is fine. No image at all though and no backlights seen at all when TV is cut on. Sound works as well, I can hear when I toggle the menu options it is responding. I have attached some images so hope this helps as I have done no troubleshooting yet. I will test the main filter cap and get back as I need help testing the led output. Thanks for you help here!
Samsung 60" LED Issue (UN60H6400AFXZA)
Re: Samsung 60" LED Issue (UN60H6400AFXZA)
I see www.shopjimmy.com sells the complete board kit for this here: http://www.shopjimmy.com/samsung-un6...-version-1.htm
You think its worth getting or we should rule out the LED strips first? -
Do you get the baklights when you power up the power supply/LED driver board without the cable connected to the main board?Never stop learning
Sounds like something is loading down the PSU enough to knock out the backlights. Try reconnecting the mainboard and retesting.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
OkDon't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
Let me obtain some schematics for this TV...Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
That means the main board is not sending the BL-ON (BLU-ON) to turn on the backlights circuit.
Try disconnecting the T-CON board, heat and cool the main board to see if it has any affect.Never stop learning
Common issue is the Spi Flash Ic which contains the firmware corrupting and not turning the set on. If you can source a chip with the firmware on replace it if not replace the motherboardPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 PhotosToday, 03:47 AM -
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
by ManucslHello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump... - Loading...
