TC-P50S30 TNPA5351 has failed twice in three days.
  • johnboy1313
    • Nov 2012
    • 1959
    I repaired this set a few weeks ago by replacing three 30f131 fets and sold it. After three weeks, it quit again. I opened it up and found the same three fets were shorted. I replaced them again and this time, used screws from an older Panasonic with lock washers when installing the SC. The owner picked it up around 9:00 last night. At 10:00 last night, I got a text saying it had blown again.
    Any guesses as to what I could be missing?
  • tw2005
    • Oct 2011
    • 6458
    Re: TC-P50S30 TNPA5351 has failed twice in three days.
    I don't have any great suggestions but which 3?
    The One I did needed 4 30F131. Q402,403,422,423
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Replace all 4 : Q402,403,422,423 and also D401,421. And measure R402,403,422,423. Can't remember ohms on those but compare the 4 to each other?
      Edit: lol @ TW2005,you beat me to it again,haha
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        All solder the SC power wires directly to the Pcb after replacing all 4 again.
          Why?
          • johnboy1313
            • Nov 2012
            • 1959
            If I remember correctly, if you are looking at the board, installed in the TV, it was the row of fets closest to the connector. The bottom one, the next one up, and the first one above the two diodes. I don't remember their location names.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Originally posted by tom66
              Why?
              Check Ali E's thread about possibly causes of failure for these and other S/C boards.
                You should always replace the transistors in the lower half when replacing the upper half.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Why?
                  Because I killed an SC in a 42" by merely Touching the cables and causing the (cruddy) two-pin plug to arc...
                  I solder directly all Panasonic SC and SS boards power-supply cables now, Both Ends ...
                  TELEFIX
                  • HI-ZEES
                    • May 2016
                    • 3
                    • NIGERIA
                    hello good day every one am new, don't really know where and how to post here but i would appreciate if someone will guide me.
                    here is my challenge
                    my hp elitebook 8440p core i5 flashes power light 8 times but refuses to on have tried doing a lot of troubleshooting like ready IC, capacitors, charging charger, memory etc. but still will not on. pls i need help
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      I think you have messaged the wrong forum.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Also doubt its a transistor fault, even if one was leaky they would blow instantly so something eles must be blowing them.
                          Hm, I always thought the connectors were decent - perhaps the contacts were worn from previous arcing events or something of that sort.
                            This isn't necessarily true as it's more than possible that a transistor could be wounded early on and then fail later. The energy dumped into it by a short circuit could cause damage to the die that may not show up on any tests except by using an electron microscope - so *always* replace the other transistor in any half-bridge.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Already ordered the kit. I'll replace all four fets, and the two diodes and probably the four resistors as well.
                              • tw2005
                                • Oct 2011
                                • 6458
                                yeah , I'd do the 4 like Tom suggests. That's the same banks I replaced but did the 4 and I also used FGD4536 which are smaller package Dpak and it's been good for 18 months now.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Got the kit in yesterday and installed the whole 13 piece kit this evening. I even soldered the cables on both the SS and the SC. it just popped again. Time to part this one out. I'm done.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Tragic. Economic loss . It would bug me not knowing the cause. Thankfully the wins outweigh the losses. Know the feeling. I'm on day 4 on a 4782 . No worky no smoke 7 blink
                                    • ahmedtou
                                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                      by ahmedtou
                                      help me please
                                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                      I will share all the details with you, including the disc information.
                                      Code:
                                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                      Current Profile: BD-R
                                      Disc Information:
                                      Status: Empty
                                      State of Last Session: Empty
                                      Erasable: No
                                      Free Sectors: 12,219,392
                                      Free Space: 25,025,314,816 bytes
                                      Free Time: 2715:27:17 (MM:SS:FF)
                                      Next
                                      08-27-2025, 08:49 AM
                                    • keldeo
                                      How many of you have seen failed Panasonics!?
                                      by keldeo
                                      In my experience, I've seen failed Taiwan/Chinese caps, obviously as I'm sure all of us had. I've also seen the defective Nichicon and Chemi Con series. Even seen failed Rubycons (MBZ I think?) if they are exposed to a lot of stress and heat. I've never seen failed Panasonics until now! Not just one, but 3! Also in seemingly random locations on the motherboard. Next to the RAM and CPU, but not t part of the VRM. It felt like I spotted a Unicorn, so I had to make this post. Motherboard is a IPIBL-LA. OEM from HP.
                                      Unfortunately, I do not know the history behind this PC, it also had...
                                      Yesterday, 02:36 AM
                                    • survivalbloke
                                      MacBook Pro 13" Touchbar, model A1706 - Critical software update failed
                                      by survivalbloke
                                      This machine came in with a no power complaint after a liquid spill. The only damage I found was on the two USB-C boards, so I replaced those, and the machine charges and fires up. However, if the internal LCD is connected to the logic board, when it boots, I will get a critical update failed warning and the only options are to shut down or try again - it's a loop. I am able to start up fine in safe boot. If I disconnect the internal LCD, I am able to boot normally to the OS. The customer doesn't want to invest any more money beyond what I already charged. Unfortunately, based on what I...
                                      11-21-2025, 01:12 PM
                                    • Zarithya
                                      Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
                                      by Zarithya
                                      I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
                                      11-02-2025, 06:26 AM
                                    • paparazzo79
                                      HDD in external enclosure failed, may I use external enclosure with other HDD?
                                      by paparazzo79
                                      Hello.
                                      I own Seagate Expansion drive which for me unknown reason has failed yesterday.When connecting to PC I am getting access denied message and whole partition in Disk Managment is in RAW format.
                                      So I dismantled the case thinking I may use the inside HDD as internal sata device in a computer but even like that I am getting access denied message.
                                      The drive is Sagate Exos.
                                      My question is may I use the enclosure with other internal drives (I own 3 internal 3.5 inch WD drives with 13TB capacity)?
                                      I mean maybe that is even not advisable since electronic card (from pic...
                                      10-28-2025, 01:01 PM
