Samsung LNT4669FX/XAA random horizontal line and restart issues
  • Super_dork
    What am I doing
    • May 2016
    • 6
    • Usa
    Hi! I'm new here and trying to find some help. I've been searching and I'm just not confident that I've found issues that are exactly like what I have. I was given a Samsung LNT4669FX/XAA with known issues to tinker with to see if I can get it working. Apparently they had some service done to it at some point, but I'm not sure what that work was. I'm familiar with the bad caps issue and have done that repair on another TV before. I checked this one and all of the Caps look fine. So here are my symptoms:
    1) When first plugged in, the red light flashes then the TV makes the startup chime sound. The screen will come on but the image is green and snowy then it will click off then back on. It does this several times, eventually the startup sound stops playing and it just makes the click sound. After a little while, it will start up and have a great picture. It seems like a cap issue, but since they aren't damaged, I'm skeptical. Also, once it has warmed up, I can turn it off and back on after a few mins and it powers right on.
    2) Once powered up, if I add an input on any of the HDMI ports (haven't tried RCA ports) I will get a few random horizontal lines that will flash of for a split second then go away. I got a video of this. https://youtu.be/Z8dK6gRylg4. I tried 3 HDMI cables and tried my Roku and TiVo and switched the Roku between 720p and 1080p output. Nothing affected the lines. The video shows the Roku main menu and there is some ghosting or something where the menu duplicates and slides off the screen (don't know how to describe this). If I navigate off of the main Roku menu or play video from any Roku app (Netflix, Hulu, etc) or switch over to Tivo, the screen flicker and ghosting goes away and I just have the random horizontal lines that flicker on and off periodically, but there is no other flicker to the picture.
    As for troubleshooting, at this point I visually checked the caps and they seem fine. I also fully disconnected the T-CON board and the lines don't appear. Just a black screen with a glow around the edges.
    The previous owner said it was the main board that was bad, but I'm not sure how he arrived at that conclusion. It feels like I'm dealing with 2 separate issues, but I'm not experienced enough to know for sure. I'd rather not just start swapping out parts willy nilly and I'm guessing there are some other ways to diagnose things to get a better target. Any help would be greatly appreciated.
    Thanks!
  • SLK001
    • May 2014
    • 264
    Re: Samsung LNT4669FX/XAA random horizontal line and restart issues
    These guys have known bonding tab issues. I have a 40" version of this series that would do what you said.
    I believe that you have two issues. One is the bonding pad issue. You can sometimes put some resilient material to press the tabs down (I used a piece of plastic foam). You can easily tell which tab is giving you the problem by pressing on them individually.
    Second problem is the power supply (caps). One or more is probably bad - you just haven't found the bad ones yet. Look also on the main board for a bad cap. Monitor the voltages coming off the supply to identify problem area.
      Can we see good clear pictures of the whole back side of the TV so we can see all the board, also good clear pictures of the power supply board and the main board?
      • Super_dork
        What am I doing
        • May 2016
        • 6
        • Usa
        These are the pics I have at the moment. I can take some more this evening and post.
        • Super_dork
          What am I doing
          • May 2016
          • 6
          • Usa
          I haven't gotten back to the TV to get pics yet. I ordered a set of caps and I also found someone on eBay selling all the boards out of this model. They should arrive this week. my plan is to swap the boards one at a time to see if anything changes. If the power board helps with the startup issue, I'm going to replace the caps. If the boards don't help the screen, I'll look at the tabs issue as well.
          • Super_dork
            What am I doing
            • May 2016
            • 6
            • Usa
            I replaced the caps and seem to have the same problem. It eventually warms up and stays on but has static lines.
            https://youtu.be/ykqMAkp5JBk
            • Super_dork
              What am I doing
              • May 2016
              • 6
              • Usa
              Not sure if anyone is reading this but I could use some direction.
              I got a set of used boards in and started swapping. The only change in symptoms was when I swapped the PCB SUB FRC board. When I did this, I got the white screen - black with white light only coming in from the sides and warms up to be mostly white. This makes the power cycling stop. I have switched the T-CON and the FRC boards around every way possible. If I unplug the cable coming from the main board going to the FRC, and the power cycling stops Regardless of which other boards are installed.
              So, I'm stumped. I don't know what to do next. Please help!
              • 97Kouki
                • May 2016
                • 23
                I agree with the original assessment. The horizontal lines you mentioned sound like bonding tab issues. I have a HannsG monitor that shows the same symptoms. There is no fix.
                Bonding tab issues and symptoms change with the heat of the panel. When mine is cold almost half the screen is covered in horizontal lines. After an hour or so only a handful remain. Leave it on a couple days and the display is perfect. It sounds like yours is shorting out though.
                • sputnikoff
                  Roku Rnsmu7536 menu issues
                  by sputnikoff
                  Hi: I have this Roku rnsmu7536 that has menu all messed up as in short video .Have a suspicion that it's the motherboard.The screen comes on and on screen display keeps going from tv to component to hdmi1 etc keeps cycling....
                  09-02-2023, 05:28 PM
                • gretti
                  MSI Z370-A Pro, works but does not power off or reboot and USB issues
                  by gretti
                  I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                  The MSI BIOS included the ME firmware for the board. The size...
                  10-16-2025, 02:14 AM
                • Ihandyrepair
                  Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                  by Ihandyrepair
                  Hi guys
                  I just started fixing 4k TV few months ago. so I am still learning a lot
                  I got this tv from friend complaint is ghosting or horizontal lines on image.
                  never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                  then it started to show the ghosting white image.
                  I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                  it has 3 thin small boards at the bottom of the...
                  12-05-2022, 04:18 PM
                • kotel studios
                  Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                  by kotel studios
                  Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                  In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                  08-06-2025, 02:07 AM
                • SoulFreeze
                  Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                  by SoulFreeze
                  Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                  After repairing the above issue, I realized the following remaining problem,
                  Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                  The computer recognizes headphones are connected and displays a popup in windows
                  Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                  06-21-2025, 09:53 AM
