UE55JU6870 transport damage question (moved)
  • Diah
    • Feb 2013
    • 6435
    Originally posted by ReeceyBurger123
    I got that, I was selling a brand new Samsung 55" 4K nano crystal Led Smart Tv for £600.
    i just bought for 140 EURO over this weekends via ebay from known company new Samsung UE55JU6870 had transport damage, but the panel not Brocken. my questions, did the panel had on the sides Tabs bond?
    see the Photo
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: UE55JU6870 transport damage question (moved)
    Looks like the panel is damaged but not broken. Tear it down to the frame and try pressing on the tabs. Also be very careful to get them side drivers back in and not rip them off.
    • Diah
      • Feb 2013
      • 6435
      still not arrived here, tabs re soldering no problem to me, just i was asking are this kind of 4K nano crystal had also Taps on both sides... ?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yes they do, theres alot of Pixels to manage, GIG drivers would be hard to do with 4k so they have them on the side.
        • Diah
          • Feb 2013
          • 6435
          as i expected the right side TAP was brocken, unrepairable , refund
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ahh no, the screens used in thw JU8 series are crap and way and have high failure rate.
            • rblack711
              Vizio D55un-E1 COF Lifting Tabs - Not!
              by rblack711
              Relatively new to TV repair - as you will see. Rescued this TV from the curb. No backlights, but I could see an image on LCD with flashlight, so suspected bad LED strips. When I got to the part of lifting the LCD off the frame, it was stuck a little bit from some tape used to hold down a thin layer of foam around the frame. I saw 8 tabs on each side of the LCD that I haven't seen on any of the 3 TVs that I have taken apart before. I immediately thought, wow the engineers that designed this were thinking about the serviceman when they put these lift tabs on here - good for them. So I started yanking...
              08-24-2022, 12:52 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Joel Ohana
              Lenovo IdeaPad 3 15IAU7 that suffered water damage
              by Joel Ohana
              I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
              Symptoms:
              • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
              • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
              What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
              03-06-2025, 11:25 AM
            • azozexd
              Need help hp 725 g3 liquid damage
              by azozexd
              Hello freind i have hp elitebook 725 g3 White liquide damage
              after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
              could some one tell me the value of this resistor
              Thank you...
              12-15-2024, 06:01 PM
            • mon2
              A1466 Macbook Air (Liquid damage repair)
              by mon2
              Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
              Macbook AIR Model A1466 Diagnostic 09-01-2021
              Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
              Problems & Resolutions
              1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
              09-01-2021, 09:31 AM
