Lg 50pa4500
  • bjorkson
    • Apr 2012
    • 127
    Lg 50pa4500
    Hello, trying to do a test pattern on my LG Plasma TV, since I am getting a rainbow color screen on my TV. VA/VS tested good when power on. I have this logic control board, can't find my Auto GEN to jump it. Anyone know? This is the logic board I have.
  • bjorkson
    • Apr 2012
    • 127
    Re: Lg 50pa4500
    Can anyone assist please? Control board number is EBR 75271801. Thanks.
    • mmartell
      • Oct 2013
      • 3189
      Re: Lg 50pa4500
      At the risk of answering incorrectly I think it's the pad in the small square just between/above the two connectors along the bottom of the board. I think you have to ground it.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: Lg 50pa4500
        Jumper these two pads next to R452 and R451 and remove Lvds to run the PDP test patterns.
        • bjorkson
          • Apr 2012
          • 127
          Re: Lg 50pa4500
          Got it, ran the test and test pattern came out like it should, looks like I have a bad main board, will order one and let you guys know if that fixes the problem. Thank you for the assistance.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: Lg 50pa4500
            Ok cool, what pins was it to run Tp on these ?
            • bjorkson
              • Apr 2012
              • 127
              Re: Lg 50pa4500
              It's not label, but the pins below R451 and above R452.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Re: Lg 50pa4500
                Ok as I said cool, let us know what happens when you replace the Mb.
                • bjorkson
                  • Apr 2012
                  • 127
                  Re: Lg 50pa4500
                  Just wanted to give you guys a update. Main Board came in yesterday, looks to be a good main board I received. TV is up and running like a champ! Thank you guys for all the help!.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Re: Lg 50pa4500
                    Thanks for updating the fix im sure it will help others out too.
                    • Yanleb
                      LG 60PK550 Logic Control Board EBR63450301
                      by Yanleb
                      Hi all, I just want to share the repair of my 60PK550-UA TV set.
                      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                      C57: 3.30V
                      C61:...
                      07-20-2023, 12:38 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      by ohren
                      09-08-2023, 05:24 PM
                    • korben_dallas
                      Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                      by korben_dallas
                      Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                      I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                      I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                      MY QUESTION:
                      I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                      02-14-2024, 12:23 AM
