Hi chaps wondering if any knows what the eq pn would be for this Ic in the title. Cheers.
ICE3BR0665JZ Equivalent ?
https://www.facebook.com/Telford-Tel...7894576335359/Tags: None -
Re: ICE3BR0665JZ Equivalent ?
You can purchase the same chip on ebay. Here's like link. http://www.ebay.com/itm/INFINEON-ICE...-/311032803295
Cheers -
I would buy it but the postage is £124 so will leave that one thanks.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
I reckon you could make this work.
http://uk.rs-online.com/web/p/pwm-cu...llers/7532964/
looks to be same specs just 8 pin
On the DIP7, pin 6 is missing, on the DIP8 it's NC so snip that off
On the DIP7, pin 4 is NC, pin 5 is drain
On the DIP8 4 & 5 are drain so depending on the pcb mask you may be able to leave pin 4 if it's just going to a land of no connection or snip that off and pin 5 drain will match up with pin 5 drain of the DIP7 locationComment
http://www.ebay.com/itm/ICE3BR0665JZ...gAAOSwo8hTrP6d
or
http://www.ebay.com/itm/5PCS-ICE3BR0...YAAOSwubRXGF1o
they any good for you ?Comment
Hi Tw2005, guess what I have that exact Ic soldered on now. I snipped off pin 4 and pin 6 before starting this but the Tv wont even start with the J version installed looking at the data sheet they are slightly different. So it needs to be the JZ version will link data sheets.Last edited by ReeceyBurger123; 04-27-2016, 03:10 AM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Data sheet for 0665JZ:
https://cdn.badcaps-static.com/pdfs/...e6bc663c10.pdf
Data sheet for 0665J:
https://cdn.badcaps-static.com/pdfs/...6c177f8dcd.pdfPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
It is important to match switching frequency, to match the magnetics and the control loop, and to select a part with the same start circuit (HV JFET block or series resistor)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yesh its a Samsung PS60E550 the Ic is on the Ymain and is faulty.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
What do you mean mate ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Sorry misread what you put, also looks like there is nothing to match this well I cant find a thing. Cant find any in the Uk though
Cheers looks like I might have to order these.http://www.ebay.com/itm/ICE3BR0665JZ...gAAOSwo8hTrP6d
or
they any good for you ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
You get a hit with BN81-04780A at CHS Interactive but appears to be the 8 pin "J" version but elsewhere they quote the "JZ" version DIP7.
Could there be something else wrong and it's not the IC you just installed?Comment
Well I read a post by Tom and he also said the Ic is commonly known to fail. After freeze spraying the Ic direct the set worked so I presume its the fault. But with this other one the set does not work at all.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Sounds conclusive, Just surprised on paper it looked close, did you find anything different?Comment
Available here on Ebay
http://www.ebay.co.uk/itm/INFINEON-I...-/311032803295
Edit
Just seen the postage...riduculousLast edited by dick_barton; 04-27-2016, 03:38 AM.Willing to help but I'm no expert.Comment
by ary89i need to know equivalent and pin to pin similiarities for RT6575D, i have Asus ROG GL503 from 2017 won't charge and power on, 19v present, put the charger on and with thermal camera, that ic getting hot11-12-2025, 09:44 PM
by karloxGood evening, colleagues.
Does anyone know an equivalent or a compatible replacement for the uP9002P IC (power controller)? Alternatively, does it come under any other marking or code on different boards?
Any insight or cross-reference would be greatly appreciated. Thank you in advance!09-01-2025, 08:43 PM -
by peter_wheatHi All,
I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing... -
by khelaneHello
I wanted EQUIVALENT IC SOUND
---- ALC 3204 ----
Device
DELL 5400
TNX -
by magnehHello everyone
Got a motorbike PCB that had 3 burned diodes.
The smaller ones have the marking PJ78 GS1M
And one larger one PJ78 GEX
Can someone help me identify them so I can be able to replace with same or equivalent?
Photos attached
Apreciate !
Thank you... - Loading...
