Re: VIZIO E550i-B2 Sound - No Video Problem
Yea, I thought about that afterwards. Would have been better to solder in wires. But I just glued the connectors down, I didn't glue the boards together. TV is working perfect.
I wouldn't glue it like that. You never know when you might have to actually pull the two boards apart. It is better to assemble the two boards together, then solder the broken joints, then reinstall in the chassis as a single unit (both boards connected). This will minimize the stress on the joint and since it doesn't move, should last a long while. My VIZIO has been working since I repaired the connector and started this thread.Leave a comment:
Wow, So I was working on this TV today but before I even opened it I came onto Badcaps Forum and see what I could find. Sure enough my connector from the Power board to the LED Driver board is like barley hanging on. So I just added super glue between the plastic and the board and after I resolder it I will add Gorilla Glue to the top. I will do the same for both sides.Leave a comment:
something bad has happened to one tab. It is causing "loading" across the panel which affects mostly timing of the signals. Removing the tabs takes that away. Of course, the set has been "saved" BUT no manufacturer puts in "things" that can be easily dropped or removed. The set will have some "compromise" and ultimately the tabs on the other side will have to work harder which will shorten their life span... but for now, enjoy your set.Leave a comment:
Nice job budwich! Can't believe the panel survived the abuse I put it through!
The biggest tragedy was the front bezel/frame that holds the panel in, all the tabs broke removing it, so I will have to glue it or leave some tape on it.
Appreciate the help immensely!
I'm curious, why do all tabs need to be removed, and what are we solving exactly?Last edited by kevinm34232; 11-06-2017, 08:30 PM.Leave a comment:
There are tabs on both sides. I'll give it a try and see what happens.. ThxLeave a comment:
you basically tear all the tabs on the right side off. They are thermally bonded to the screen as soldering at the manufacturing stage would be detrimental to the panel at that point. But this may only work IF there are tabs on the other side of the panel to drive the screen.Leave a comment:
sorry ya i thought I had posted a pic, but it is just basically the left half of the screen perfect pic, with a blank right side. I have checked the components not finding anything wrong so far. What's the process of removing the side tabs? I've already considered the panel bad so nothing to lose trying..Leave a comment:
:-( that means that the connections are formed somehow thru the panel itself to feed the side tabs. Personally, I have only seen a 70 in. I do believe others on this forum have been successful at pulling the tabs on "lesser models".... 60's for sure but not sure about 55's. Are the tabs, the same on both side of the set?
You still haven't posted a picture of the display showing the resulting screen with the tcon cable disconnected. You might try comparing both ends of the bottom edge boards (ie. right and left sides) and see if you can spot any differences that might point to a bad component that might be replaceable.Leave a comment:
look at the bottom corner of the panel.... how are the side tabs / sides "tab cables" connected to the bottom edge boards? On 70 in units, there are small unclampable flex / ribbon cables running from the bottom boards to the side boards. On 55 in, their design might not have that "feature" (like some of the 60's).... as the tabs might be interconnected in some fashion thru the panel itself. how many bottom edge boards are there? I assume there is more than one... maybe one per "half". If there is more than one per half, they are interconnected with unclampable flex cabling. You can unclamp the cable on that side. It should give you more picture ... maybe 2/3 and further confirm the "postulation" that the right side is the issue. IF so, then you will have "tested" most of the connection path and only have the last little bit of bottom edge board along with the side tabs. You can then check that portion of the bottom edge board to see if anything "jump" out at you as there might be a component on the edge board that has a problem and maybe replaceable (with some effort). This would be before the "final / last hope" of tab removal which has no "back tracking mode" there after.
you might post a picture of display that you get.
I see from your picture that there is only one edge board per bottom half.... :-( so you need to look at the lower right corner to see what's up with the interconnection between the bottom edge board and the right side.Last edited by budwich; 11-05-2017, 06:25 PM.Leave a comment:
from your "test" doing the right side disconnected, it would appear your issue is on the right side (assuming your brain dead moment tested the disconnected left and got no picture at all... :-) ). Look on the right side, to see how the tabs are connected and see if you notice anything different amongst them (ie. heat marks, etc). Potentially depending on how the bottom edge boards of the panel are connected and how many there are, you can further your "testing" by unclamping the flex cable interconnecting the edge boards on the right side... if possible. This may give you even more picture, you can go from there.... hopefully.Leave a comment:
Ya i have seen this on the 70" Vizios and some have luck with that. Something about cutting the trace on the tab to the bad transistor?Leave a comment:
so it potentially can have tabs removed to save it... IF it is has side tabs on each side.Leave a comment:
Yes OK sorry update is there is 12V to t-con before and after fuse.. I tried a new main board, same problem. So now that main and t-con were replaced, I'm thinking it's a bad panel. Could that be without shorting anything on the t-con?
Nevermind, had a brain dead moment forgetting to disconnect each side of the panel from the t-con, and could only see left half the screen come on normally with right side ribbon disconnected.Last edited by kevinm34232; 11-03-2017, 08:37 PM.Leave a comment:
Edit! dick barton beat me too it
have you got voltage too the tcon fuse? as could be a bad mainboardLeave a comment:
Have you a supply to the tcon?Leave a comment:
I did the solder joints for the back light problem, now just have no picture but have back light. He said a tried a new t-con board and it didn't help, so I'm thinking maybe the panel..Leave a comment:
May be worth watching
https://www.youtube.com/watch?v=NKdSrAH8_hsLeave a comment:
by ajshoeHave a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
Does this mean remove right side (from front of TV) tabs ?
Like a second opinion before possibly destroying set.... -
by soerenI am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
All happened after the battery ran out of power overall several days when I was on vacation.
I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery... -
by JRadeWhen I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
I replaced the capacitor C303/0.047F, nothing changes.
I'm asking for help, what should I do next?
Thanks in advance!...-
by FrancescoVGood morning everyone,
I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
The firmware reported is the following:
M:1.00/11107BLP
D:?.??/????????
O:1.00/11107AL
The DSP firmware given the question marks seems corrupt.
On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...-
05-11-2025, 02:59 AM -
This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...09-12-2024, 02:00 PM
- Loading...
