Sharp Power Supply Repair IC7905
    I'm having a problem with a Sharp Power Supply P/N DPS-485BP-1 A.
    IC7905 TNY264PN and R7914 were blown. New Parts did not fix the problem. Other Sharp Power Supply Boards use these same components for the 5V Standby. Please help with a solution, schematic, or source for a replacement Board. Model Number is LC-65E77UM. Thanks.
    Re: Sharp Power Supply Repair IC7905
    Is this you board?
    http://www.shopjimmy.com/sharp-rdenc...unit-board.htm
    Pictures of your board top and bottom side?
    How about other low Ohms resistors in that section, I.E. R7918, R7853, etc.
      Is this you board?
      That's the one. Those resistors are good. I have a working DPS-286AP that has the same standby circuit. I have swapped the IC, opto-isolator, capacitors, and transformer. The non-working board has 1.6V where the 5V should be. Control voltage on pin 4 reads 1.1V. Should be .83V.
        I have the same problems on IC7905 TNY264PN and R7914 were blown too , I already checked all power resistor on the board, diodes and transistors , does somebody have diagrams of Delta DPS-485BP-1-A ?
