Panasonic TC-P42ST30 14 blinks.
Re: Panasonic TC-P42ST30 14 blinks.
Points towards SN then I'd think. You say no shorts but if it was P or A then it should have triggered with those alone.
14 with SS removed but SN connected, no 14 with it disconnected, ss connected.
Have you checked any of the IGBTs on the board for shorts like the 30F131?Comment
stick your probes into the connector and measure the dc voltage. Most of the large surface mounts are IGBTs, i.e. Transistors and look for the ones which are marked 30f131 as they are common ones to go. Don't know the board but could have RJP30H2 I think also could be shorted.
Failing that, measure the resistance across sn2, it may not be dead short could be low in ohms though.Comment
If you know the TV was on with that test before no, but if in doubt yes you could measure Vsus because if Vsus is up then the TV is running.
If the TV is running with just the A & P boards then the 14 blink is being caused elsewhere.Comment
TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
definitely wrong, should be hundreds of K to M ohms
The RF.... devices are diodes. Usally once you pull the shorted 30F131 transistors off these will check okComment
Picked up one of these tv's locally that had a cracked screen. I checked the SN board and no shorts that I know how to check so I put it in.
The tv turns on, no blood bling LEDs. Only the right side of the screen works.
Does it look like a bad panel?Attached Filesif you find these attachements useful please consider making a small donation to the site
Too hard basket for me. Interesting display, looks like a few things could be wrong.
Looks like misaligned panel ribbons on the SN.
bars on the left, no idea.
vertical noisy bar, could be shot panel driver ic on the bottom panel ribbon
Have you checked the C board on that bad side is all connected correctly, nothing left disconnected or tried swapping out with the other c-board?
The boards may be ok for sale but I think I'd want to see them work normally.
SN board is probably the one you'd want to test in a working TV to be sure.Comment
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by nobbnobb1Hello,
I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
2x DG302 (Q16051)
2x RF2001 (D16041)
2x 5.6 ohm SMD resistor
1x BD8694 IC
I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated... -
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
by mmischniGreetings friends,
I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly.... -
by dj01fadHello again.
I have a little problem with my tv: it had the 7 blinks failure, and I repaired the SC board. After that, it starts for 1 second and goes to 8 blinks. Everything on the SC board looks to be fine but I discovered that I have one shorted transistor on the SS board, Q102. I have a new one but I am wondering if it would be better to replace also IC 191.
I did not check the SS board before the 8 blinks. Do you think it's possible that it went off together with the SC board or it died after my repair? - Loading...
