Panasonic TC-P42ST30 14 blinks.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P42ST30 14 blinks.
    Originally posted by Malachi
    Just tried that. No blinks.
    interesting, so it turned on and voltages were present like Vsus? Would suggest a deeper look at the sn and ss boards.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      What should I do?
      I didn't check the voltages after disconnecting the connections I was told to do. Just checked the blinking.
      • tw2005
        • Oct 2011
        • 6458
        Put it back together, disconnect ss11 and turn on and see what happens. Just remember not to reconnect that cable straight away or bleed the voltage off
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          I'll try that when I get home but if I remember correctly, I tried that last night and still got 14 blinks.
          When I connect everything and disconnect sn2, I get 7 blinks.
          I'll confirm this afternoon.
          • tw2005
            • Oct 2011
            • 6458
            Points towards SN then I'd think. You say no shorts but if it was P or A then it should have triggered with those alone.
            14 with SS removed but SN connected, no 14 with it disconnected, ss connected.
            Have you checked any of the IGBTs on the board for shorts like the 30F131?
            • tw2005
              • Oct 2011
              • 6458
              What should I do?
              can't hurt to try it again and back probe the p2 or p11 and see if Vsus is up
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                #27
                Back probe? I don't know which ones the IGTBs are.
                • tw2005
                  • Oct 2011
                  • 6458
                  stick your probes into the connector and measure the dc voltage. Most of the large surface mounts are IGBTs, i.e. Transistors and look for the ones which are marked 30f131 as they are common ones to go. Don't know the board but could have RJP30H2 I think also could be shorted.
                  Failing that, measure the resistance across sn2, it may not be dead short could be low in ohms though.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #29
                    Ok, that's how I checked the voltages before but with all boards and connection connected.
                    You want me to check the voltages with the sn(Ysus) board disconnected from the psu ?
                    • tw2005
                      • Oct 2011
                      • 6458
                      If you know the TV was on with that test before no, but if in doubt yes you could measure Vsus because if Vsus is up then the TV is running.
                      If the TV is running with just the A & P boards then the 14 blink is being caused elsewhere.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        #31
                        Sn2 reads about 32K ohms.
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #32
                          With my meter in diode mode, these transistors(?) beep when one lead us in the middle and the other on an outside leg.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #33
                            I get 15v on both F15V with the SN board unplugged. It doesn't stay at 15v though.
                            Relay clicks and it starts dropping.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              #34
                              Then those devices are short....
                              TELEFIX
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #35
                                Figured. I see repair services on eBay for SN boards with 14 blinks. Now I have to decide if it's worth it.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  definitely wrong, should be hundreds of K to M ohms
                                  The RF.... devices are diodes. Usally once you pull the shorted 30F131 transistors off these will check ok
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    #37
                                    I purchased a repair service from eBay. Let's hope that is the problem. If not, I'll have a good SN board to sell. Lol
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      #38
                                      Picked up one of these tv's locally that had a cracked screen. I checked the SN board and no shorts that I know how to check so I put it in.
                                      The tv turns on, no blood bling LEDs. Only the right side of the screen works.
                                      Does it look like a bad panel?
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        #39
                                        Should I just start trying the other boards?
                                        Also if it is the panel, is it safe to say that the boards are good? Can I part them out? The SN board alone is expensive. I paid $25 for the TV.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Too hard basket for me. Interesting display, looks like a few things could be wrong.
                                          Looks like misaligned panel ribbons on the SN.
                                          bars on the left, no idea.
                                          vertical noisy bar, could be shot panel driver ic on the bottom panel ribbon
                                          Have you checked the C board on that bad side is all connected correctly, nothing left disconnected or tried swapping out with the other c-board?
                                          The boards may be ok for sale but I think I'd want to see them work normally.
                                          SN board is probably the one you'd want to test in a working TV to be sure.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • nobbnobb1
                                            Panasonic TC-P50U50 Powers Off - 8 blinks
                                            by nobbnobb1
                                            I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                            2x DG302 (Q16051)
                                            2x RF2001 (D16041)
                                            2x 5.6 ohm SMD resistor
                                            1x BD8694 IC
                                            I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                            03-21-2023, 08:33 PM
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • mmischni
                                            Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
                                            by mmischni
                                            Greetings friends,
                                            I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
                                            First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
                                            09-06-2017, 08:52 PM
                                          • dj01fad
                                            panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
                                            by dj01fad
                                            Hello again.
                                            I have a little problem with my tv: it had the 7 blinks failure, and I repaired the SC board. After that, it starts for 1 second and goes to 8 blinks. Everything on the SC board looks to be fine but I discovered that I have one shorted transistor on the SS board, Q102. I have a new one but I am wondering if it would be better to replace also IC 191.
                                            I did not check the SS board before the 8 blinks. Do you think it's possible that it went off together with the SC board or it died after my repair?
                                            10-25-2020, 06:05 PM
