panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
  • dj01fad
    • Sep 2014
    • 92
    • romania
    Hello again.
    I have a little problem with my tv: it had the 7 blinks failure, and I repaired the SC board. After that, it starts for 1 second and goes to 8 blinks. Everything on the SC board looks to be fine but I discovered that I have one shorted transistor on the SS board, Q102. I have a new one but I am wondering if it would be better to replace also IC 191.
    I did not check the SS board before the 8 blinks. Do you think it's possible that it went off together with the SC board or it died after my repair?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
    You should be fine with replacing Q102 only. I've had this fault myself.
    • dj01fad
      • Sep 2014
      • 92
      • romania
      Ok, thanks. I'll give it a go.
      Have you found the cause of this double failure?
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Just the loose screws that mount the boards.
        • dj01fad
          • Sep 2014
          • 92
          • romania
          Yeeeee! It's alive!
          It was only Q102 on the SS board.
          The SS screws were not loose. On the SC yes, they were loose, almost all of them. I had some screws with washers and replaced all of them.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Good job! Those damn screws have kept a pretty good supply of cash coming my way.
            • Andre Gilbert
              by Andre Gilbert
              11-20-2024, 08:52 PM
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • CrewmanRedShirt
              Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
              by CrewmanRedShirt
              Hello all,
              As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
              07-13-2024, 11:02 AM
