M471i-A2 No picture, no sound
  • vbrad511
    • Feb 2015
    • 70
    I picked up this Vizio a month or so back from a gal who said it had been fine until the cable guy did something on/in her house. The backlights come on, but no visible picture, and no sound. First instinct told me main board. I've changed it, no difference. I got a good deal on a power board, still no difference. The screen lights up dark gray, and does change a bit with the buttons on the remote. I've been reading here on the site, and anywhere else I can for tips on this, but not finding much.
    Suggestions?
    Re: M471i-A2 No picture, no sound
    Did you check for DCV between each end of the SMD fuse on the T-con board against the chassis GND to see what you get?
    • vbrad511
      • Feb 2015
      • 70
      T-con fuse is good. 12.1v both sides with set powered on.
      • vbrad511
        • Feb 2015
        • 70
        Just swapped in a new/good tcon. Same thing, no pic. Thinking I got a bad replacement main board.
        • vbrad511
          • Feb 2015
          • 70
          At the suggestion of an Ebayer I've dealt with I did some blind searching with the input button and do have sound, just no pic. The screen looks intact, but he says there's an ic on/in the panel that tends to go bad and isn't serviceable. Looks like maybe I'm out of luck on this one.
          • vbrad511
            • Feb 2015
            • 70
            Any last suggestions before I button this up and doom it to the recycler?
            • vbrad511
              • Feb 2015
              • 70
              Got it. Turns out whoever took the tv off the wall and attached the stand again used screws that were too long. I'd pretty much given up, but then remembered Aaron talking about the IC on the panel , so I thought I'd tear into it and see if I could even see what he was talking about. I didn't get that far into it. Where the cables come out of the tcon they run directly under metal strips along the bottom of the tv. One of the mount screws had been run into one of the strips and overtightened to the point of bending the metal to the point it made contact to some electronic gizmo (lack of technical term) on the circuit the tcon attaches to. Once I backed the metal strips loose, powered the tv up, randomly trying with one or both tcon cables off, I got differing screens. Ended up with two bad tcons (must've been shorted from the electrical contact). Tried one more that I had here, bent the metal strip back into shape, and everything's working fine.
              Just gotta remember to use correct length screws on these things.
              • Electronic Handyman
                • Apr 2016
                • 58
                You're so right about using the proper length screws I've seen screws go right into the boards parts and short them out or they break something.This is not just true for TV's it's cars, toys and appliances etc I've seen many things over the years all caused by using either the wrong screws or wrong parts or by assembling something wrong etc.
                Atleast you found the problem congrats bud.
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
