When stripping a non-working tv for parts, what is the best way to test components
  • WhoHoo
    • Mar 2016
    Is there a good guide out there for testing components from televisions that do not turn on without having another television to test them in?
    • 31185
    Re: When stripping a non-working tv for parts, what is the best way to test component
    well fixing the power board is probably a good start, because then you can test the rest.
    • SluggerB
      Help with trying to fix phone that is not charging (Pics inside)
      by SluggerB
      I have two TCL A30 phones.
      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
      New Phone: Works fine, bought as a donor board to try and repair Old Phone
      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
      08-12-2024, 08:11 AM
    • Sam Scarbo
      Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
      by Sam Scarbo
      My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
      I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
      If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
      See the attached two pictures of the small...
      09-18-2024, 08:29 AM
    • chth96
      How Can I test PWM DM0365R?
      by chth96
      Hello
      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
      06-18-2025, 04:14 PM
    • User2025
      Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
      by User2025
      I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
      It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
      I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
      04-29-2025, 04:13 PM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
