Re: philips 50pfp5332d/37 keeps blowing fuse
I dont have a dmm at the moment,the board # is lj41-05253a hope these pic loaded right, thanks
Most are fitted with the Samsung LJ92-01511A power boardLeave a comment:
Also we need to know what Pus it needs with images, these Tv's use up to 3 different types of power supplies.Leave a comment:
All the bulging capacitors will require replacing too.Leave a comment:
Do you have a DMM and know how to check for S/C ?Leave a comment:
I have a 50 in philips plasma 50pfp5332d/37 that recently made a click/pop sound and stopped working. It has no power,no led lights nothing. I took the back off and noticed a few capacitors bulging, but the fuse closest to the where the ac comes in on the power boards was blown. I changed it and as soon as I plugged it back into the wall the tv made a click sound and the fuse blew immediately. Put in another fuse and done the same thing. I unhooked all the other boards from the power board and tried it again and the fuse blew again. I have read it could be the bridge rectifier, but I don't know what that looks like or where it would be on the board. I can upload some pics if that would help. Would really like to see what the bridge rectifier looks like for this tv. sorry for my limited knowledge on this, thanksTags: None
by DannyxGood day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the... -
by TipsLooking for some assistance please.
Trying to repair a PD27AOQ samsung power board.
Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
Testing it the fuse blows immediately power is turned on.
diodes dm852 and dm853 test as shorted when in the board but fine when removed.
any assistance, guidance would be appreciated. -
by RogerH58Hi all,
I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation... -
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... -
by trunks81Hello
Ive got one other 47PFL4606, only this one the fuse keeps blowing !
I allready replaced the next parts
BD901
D901
Q902
Q901... - Loading...
