LG 37LC55 Flickering and then stand by
  • rasketeplas
    • Mar 2016
    • 19
    • none
    Hi, I've a LG 37LC55 my friend give me, it wasn't tuning on and I replaced the caps in power board.
    It was working fine, but after a week of use, it started to flickering and go to standby after some minutes. And now it start flickering after 60sec of power on and then go to standby...
    The caps seems fine, they only have one week of use, so I don't know what else should I test/look/change...
    I've been reading in this forum about C901 replacement in main board, but don't know if is for this kind of problem.
    How can I check if the caps I've replaced previously are ok?
    Should I change any cap in main board?
    Thanks in advance!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 37LC55 Flickering and then stand by
    Yes failed caps on mainboard, go to my youtube chanel (MrReeceyBurger123) and watch my 32" Lg flickering screen video will help you.
    • rasketeplas
      • Mar 2016
      • 19
      • none
      Thanks, I will go and buy some caps and try it.
      But the voltage in the IC you show in your video is good, no changes after it goes to standby. So don't know if is the same thing...
      • rasketeplas
        • Mar 2016
        • 19
        • none
        I've changed the caps in mainborard, C553, C901, C915, C970, C954 and C975 but is doing the same. After some minutes of working then it goes to standby....
        How can I check if the power source is fine? And points to check the voltage and see if it's fine or any component is failing?
        • rasketeplas
          • Mar 2016
          • 19
          • none
          one thing is that just before start to flickering and goes to standy, I can hear some 'clicks' in the power source board....what can this be?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Heat the mainboard and see if the fault occurs.
            • rasketeplas
              • Mar 2016
              • 19
              • none
              Yes, it seems the fault occurs in seconds after heating the mainboard with a hairdryer....
              How can I find the faulty part?
              Here is the mainboard with the caps I've changed.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Good image but you have not changed all the caps that I did in the video you need to do that. Also have you an esr meter ?
                • rasketeplas
                  • Mar 2016
                  • 19
                  • none
                  I did not change the caps near the IC because voltage in the IC was the same as in your video after you install the caps, but I will go and buy more caps
                  I don't have an ESR meter... what do you thing about this cheap one?
                  http://www.ebay.es/itm/322041136424?...%3AMEBIDX%3AIT
                  • rasketeplas
                    • Mar 2016
                    • 19
                    • none
                    Now I've changed the same caps as you but still the same... I need to find the bad component..arrrggghhh...
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      all what you can really do is to narrow down the area your heating i sometimes use a cardboard tube and aim the hot air down it to minimise the area being heated.
                      or maybe try the opposite try freeze spray see if the set stays on longer as you can freeze small areas
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Have you checked the voltage on the 3 pin chip right side of board. It looks like a voltage regulator.
                        What is the part number on the other two other IC's the arrows are pointing to.
                        • rasketeplas
                          • Mar 2016
                          • 19
                          • none
                          The 3 pin chip is a 70SJ61, and the voltage when standby and when tv on is 4.85 , 2.45, 0 (from left to right in the picture)
                          The other 2 chips where the arrows are pointing: SC156515M
                          Voltage Standby:
                          The one at top right:
                          3.2 3.14 0 1.7 1.13
                          Top left: 0v in all pins
                          When TV on, Top left have 3.35 3.35 0 1.3 1.17 (from right to left)
                          Now i'm trying to heat each single cap with using aluminium foil with a little hole with the cap size let's see if I can find the bad one...
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            It probably is the issue as the badcaps on the Psu cause excessive stress on the motherboard ones which causes failure, keep us updated
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              The SC156515M are LVD regulators.
                              Pin 1 Enable
                              Pin2 Vin
                              Pin3 Gnd
                              Pin4 Adj
                              Pin5 Vout
                              70SJ61 Cannot find anything on this one.
                              • rasketeplas
                                • Mar 2016
                                • 19
                                • none
                                With the TV unplugged from power cord tonight, this morning I've been heating all main board, and then power on.
                                The TV then was working fine 5 minutes, and then flickering for some seconds and go to standby....
                                While flickering , the voltage in the ICs was the same, and after one or two minutes the tv turned on again without doing anything...autopower on . ...and again standby aftert some seconds....
                                Is there any way to test the power source without the main board?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  post good clear pictures of the psu and a coulple showing the connectors and any writing by them we may be able to force the psu on and place a load on the rails and see if theres a issue.
                                  whats the board number on the psu?
                                  • rasketeplas
                                    • Mar 2016
                                    • 19
                                    • none
                                    Here are the pictures...
                                    I can read here other guy with similar problem solved by replacing all caps near one IC...but I'd like to know the one broken part before doing a massive replace
                                    http://www.abcelectronique.com/forum...ad.php?t=81203
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      Im not 100% sure what pins you need to link too get the psu voltages up, also what load you need to have on each voltage rail, this may then prove if the psu is faulty or not as without a load the issue maynot show up. im sure budm will let us know what pins too link and what loads to use that way if the psu does go off you know its at fault.
                                        Can you please verify the board number? Pink marker in the picture:
                                        http://assets.shopjimmy.com/media/ca...6801-top_2.jpg
                                        http://www.shopjimmy.com/lg-eay34796...wer-supply.htm
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • DXseekerMO
                                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                          by DXseekerMO
                                          Hello everyone!
                                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                          Symptoms:
                                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                          2) TV does not appear to turn on
                                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                          4) "Power on" terminal on Power Supply has 3.26v
                                          5) "A13V" terminals have 12.9v
                                          6) Stand-by test jumper on Power Supply has 12.9V
                                          7) Optical audio jack on Main Board illuminates
                                          8) With stand-by...
                                          06-09-2021, 12:19 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
