SHARP LC-70LE550U - side driver issue?
  • G_WaTT
    • Apr 2016
    • 14
    Re: SHARP LC-70LE550U - side driver issue?
    Thanks budwich! I wasn't looking into investing a lot of time or money on the set. The living room TV has already been replaced with a 75" Sony and I'm only trying to fix it for my shops break room. I'll be a hero with the guys if this works I'll post whether or not it works once I've removed the tabs. Thanks again!
    • budwich
      • Jul 2015
      • 3097
      certainly... and you may even get a free lunch and beer out of it. The resulting picture will be as good as the day you bought it... go figure.
      • G_WaTT
        • Apr 2016
        • 14
        It worked! Thanks again budwich! For anyone experiencing the same issue, but unsure of how to remove these side tab drivers, I'll explain best I can on removing these. With the back cover off and the back of the set exposed I continued to remove the bezel which frames the front of the screen. I only removed the top and side screws. Removing only the top and side had given me enough room to remove the tabs on my particular set (LC-70LE755U). Working from top to bottom I would grab each tab and peel it forward towards the front of the set. DO NOT PULL OUTWARDS OR TO THE SIDE!!! There is only about 1/16" of these tabs connected to the screen and pulling outwards may tear the thin tab leaving remnants of said tab on the set (I had done this on a tab, but was able to remove the left overs with tweezers). It's very similar to removing a sticker. Once all tabs are removed I crossed my fingers and turned the set on. This worked out for me and this seems to be a common problem, but I also know this solution is a last resort. This solution is not reversible.
        • budwich
          • Jul 2015
          • 3097
          I can almost taste the beer... :-)
          • maple1
            • Apr 2016
            • 9
            • canada
            G WaTT did you remove the driver boards completely? I just got back to mine and used your method of peeling off the tabs then removed the boards and it looks pretty normal now. Hopefully it still works by morning that's when it allways failed before.
            • budwich
              • Jul 2015
              • 3097
              the boards are of no value.
              • maple1
                • Apr 2016
                • 9
                • canada
                #27
                If the Tv works without the boards why are they there? It's like the tv is designed to fail
                • budwich
                  • Jul 2015
                  • 3097
                  I guess they knew that they needed "spares"... :-)
                  Obviously, there are some need for them in the design / features. NOTE.... this technique used in this forum is a SAVE of the TV from the dumpster, it IS NOT bringing the set back to "factory spec". That is why it is NOT DONE by factory authorized repair centers. IF the forum had totally knowledge of the design intent, then you would have your answer. Basically, the "speculation" is that they (two sides) are used to provide improve "response"... so perhaps that is now compromised. I know of no one who has gone thru all the "testing" to figure out what works and what doesn't. In general, people are so happy that they got a "working" set again, that they haven't bothered to do much more than watch it..... kind of the "don't look a gift horse in the mouth" syndrome.. :-)
                  • maple1
                    • Apr 2016
                    • 9
                    • canada
                    #29
                    Tv is still working great my friend will be very happy thanks for all your help!
                    • CompGuru
                      • Aug 2016
                      Thought I'd add my findings. Images show that the driver got hot enough to melt the plastic surround.
                      • Shaggybamboozle
                        • Nov 2016
                        • 11
                        There are two sets up the side.
                        Did you remove all of them all the way up? Or just one of the two...
                        My tv is doing the exact same thing on the right side while facing the screen.
                        I noticed that the copper connections from the board to the tabs is damaged by electrolysis.
                        I'm assuming due to humidity.
                        I'm willing to remove the driver board and it's tabs but just want to ask exactly what you did before I go that pot committed
                        Cheers
                        • budwich
                          • Jul 2015
                          • 3097
                          I would first try cleaning the "obvious contamination" to see if it changes things... this is assuming that you see no visible issue with the driver chips as shown in the pictures in the post. Your "symptoms" might be the same but the "fix" might be different depending on the actual state of the edge board and tab drivers.
                          • Shaggybamboozle
                            • Nov 2016
                            • 11
                            The only picture I could get at all was with the side drivers disconnected at the white ribbon at the bottom.
                            I tried all the combos from disconnecting each side from the tcon board one at a time and all other combos...
                            I said the he'll with it and removed the five tabs and both side driver boards.
                            And THANK YOU.
                            Perfect picture......
                            • Shaggybamboozle
                              • Nov 2016
                              • 11
                              I also have a 70" Vizio that had a horizontal line.
                              I opened it up and there was a side tab caught folded under the lcd so I took a credit card and freed it up but the the picture went all vertical lines like an acid trip.
                              Could removeing the tabs solve the same issue even though there are no side driver boards on the Vizio just tabs?
                              The screen looks the same as the sharp did with the white ribbon disconnected and only that half of the tcon hooked up
                              • budwich
                                • Jul 2015
                                • 3097
                                yep the "save" is the same... just no physical boards to remove. There is a "main thread" on the vizio in the forum where many have worked the issue... of course, do the corner test with the tcon fully hooked up. If that doesn't work, there may be an issue with the tcon as vizios don't have as good a "protection mode" to shut down the set before some components (FETs) die... but are replaceable.
                                • Shaggybamboozle
                                  • Nov 2016
                                  • 11
                                  Thanks Budwich
                                  You've been a incredible help.
                                  Do I remove all them on the bad side as well or just the one I touched that made it screw up?
                                  I also forgot to mention that the set was on when I touched the tab that made me lose the picture.
                                  So I may have damaged the tcon I assume.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    IF your picture didn't come back during the "corner cable test", you have other issues. I wouldn't be so quick on the tab removal until you address those... because it is quite possible that the tabs are find and that some "small event" happened which took out the TCON devices. Anyways, since you know the side that you touched, disconnect that corner cable, fix the tcon (if needed), put the tcon back and you should get a picture. then go from there.
                                    My read on vertical lines in this case is much like disconnected tcon... meaning you lost something in that tcon on that side... assuming that the vertical colored lines are only on one side. :-)
                                    • Shaggybamboozle
                                      • Nov 2016
                                      • 11
                                      Budwich is this what she would look like if it took out the tcon
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        hmmm... I wouldn't expect that many lines across the screen...
                                        but... is this a vertical or horizontal picture. My take is its vertical but there aren't many visual clues... :-)
                                        Further is that half the panel or the whole panel?
                                        Lastly, how did you get to this point??? :-) sorry I can't provide more guidance as it is strange and further I haven't actually seen a vizio in the flesh, only reading / following the vizio thread as I worked on the sharp.... since the panels are the same.
                                        Does the vizio have 4 tcon cables or just two?
                                        • Shaggybamboozle
                                          • Nov 2016
                                          • 11
                                          Sorry for being vague.
                                          It started with a faint horizontal band across the middle of the screen.
                                          When I investigated, it had a side driver tab kinked under the lcd panel.
                                          I took a credit card and freed it from under the lcd and like flicking a switch the picture went to the image I posted.
                                          The picture is now vertical lines over the whole screen and it's quite psychedelic.
                                          The pic posted last night is the whole tv both sides.
                                          It has a single tcon with 2 ribbons.
                                          I'm wondering if when I touched the driver tab if I shorted something on the tcon.
                                          The only reason I'm bugging is that the sharp tv would display the same lines and patterns while trouble shooting to determine which side to remove the driver boards.
                                          Either way thank you again for all the advice.
                                          Cheers
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
                                          • claytongarcia
                                            Issue with Sharp LC-42SB45U
                                            by claytongarcia
                                            I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                                            Has anyone dealt with this issue before?​
                                            03-10-2025, 07:27 PM
                                          • larrysito111
                                            msi ms-1543 gp66 leopard 11uh-684uk ms-15431 ver2.0 gpu issue- like driver error
                                            by larrysito111
                                            the laptop has a wierd GPU problem
                                            the GPU is there when you start the laptop and has the yellow exclamation mark in control panel
                                            when you try to reinstall the GPU you install the driver and all OK
                                            but when you restart same thing (the GPU is there when you start the laptop and has the yellow exclamation mark in control panel)
                                            anyone has any idea
                                            some are telling that the bios need to be downgraded
                                            i did try to re-flow the GPU twice just to be sure but no change at all
                                            so bios i think best option....??...
                                            11-25-2024, 04:34 PM
                                          • leorivers
                                            Issue with Sharp LC-47SB57UT
                                            by leorivers
                                            I bought Sharp LC-47SB57UT 6 years ago. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until a week ago. Sometimes I couldn't get channel 5, now I can't receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5.
                                            I think the antenna and cable is ok. I doubt that this would be the tuner board or possibly something else.
                                            Any ideas where I should start?​
                                            10-24-2024, 03:11 AM
