Re: tv lcd Philips 42pfl9632d/10 Power board ko
To clarify the tv still works in normal tv mode ok?
but with a hdmi source you have issues and it turns off?
Terrible news... There is another problem...
The tv work ed fine for 2 days... Without any kind of problem... I see a lot of film, anD yesterday i gamed with ps4 (hdmi) for around 4 hours... Today begin another problem, i turned it on with hdmi, and it start to restart by self... It stai on for some second anD turned off automatically... Now i try to see Normal tv and the problem isn't present! I think that there is a ghost inside this tvLeave a comment:
Thanks for the follow-up, I am glad it is just bad diode in the stby power supply, and I guess the power MOSFET on the mian power supply board were not shorted after all otherwise the main fuse would have blown.
109 posts, whew!
You worn me out on this one.Last edited by budm; 03-25-2016, 05:14 PM.Leave a comment:
Today arrive the diodes, i changed the 6b05 and the tv work perfectly...
Thanks to everybody for the help, budm you are a geniusLeave a comment:
I found the other two, are difficult to testing for the position, anD i don't want to disoldering before the time.
I ordered the 6b05 and this two.. When arrive i replace them.
For you can resolve the problem?Leave a comment:
ok clean the board and have a search for the other diodes budm mentioned the board printing is probably hid under the dirt/dust etc.Leave a comment:
what readings are you getting on the two diodes 6bo5 6b06? in diode mode on your meter test across each diode take reading then reverse the probes and take the reading again.This is with the tv unplugged of course.
if you get a clean dry paint brush etc give the area a good clean and dust of etc if you can try to take a good clear picture i can try to point the part to test out too you.
60b06 is good, in diode mode, 400 reading and no reading when i invert the probesLast edited by Bibu; 03-22-2016, 05:12 AM.Leave a comment:
if you get a clean dry paint brush etc give the area a good clean and dust of etc if you can try to take a good clear picture i can try to point the part to test out too you.Last edited by vinceroger69; 03-21-2016, 04:29 PM.Leave a comment:
6b06 i think that is bad
i didn't find 6b07 and 6b08
the two resistor... 3b60 is a 155, and is good
3b64 is a 0 ohm resistorLeave a comment:
OK, you do have DCV to run the primary driver circuit.
You need to check those diodes I circle in the PDF. 6B05, 6B06, 6B07, 6B08
Do you have the 12VDC at 1P11 connector?
I would also check those two resistors (2M2 Ohms) 3B60, 3B34.Leave a comment:
SSB PS.
It should have +12VS which is used to turn on the switched power MOSFET 7B06 to provided the +5V.
You need to be able to read the diagram otherwise we will be spending days explaining as how to test what to test.
More likely right now the drive circuit in the primary side of the SSB power supply is not working.
You should have about 330VDC on the main filter caps 2B31, 2B50.Leave a comment:
See my edited post 98.Leave a comment:
Yes i downloaded it, but i'm not very able to understand it...
Now i Restudy itLeave a comment:
Did you download the manual?
SSB PS.
You should have about 330VDC on the main filter caps 2B31, 2B50.Last edited by budm; 03-21-2016, 02:23 PM.Leave a comment:
Maybe try to test the fuse like budm has asked black probe on tv chassis red probe on each side of the fuse what voltage do you get just be carful as mains voltage in the area your testing
There are two fuses as you can see from the print on the board as I marked in the red box.
Unless one of the fuse is not installed, the pictures are very poor so I cannot really tell.
You can also check and see if there are any DCV at both ends of the fuse with ref to the chassis GND.Leave a comment:
You can also check and see if there are any DCV at both ends of the fuse with ref to the chassis GND.Last edited by budm; 03-21-2016, 01:05 PM.Leave a comment:
well from what i understand theres a seperate 5 volts section on the mainboard that sends a voltage to the power supply that turns on a relay on the psu and then power supply outputs i may be wrong but budm im sure will confirm whilst your waiting maybe take some clear pictures of the mainboard connectors and any writing by them which tells us what the connector pins do it also maybe worth while in doing this for the power supply comnncetors too.Attached FilesLeave a comment:
i just checked the white fuse dmd 1B33 and is okLeave a comment:
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by spantorHello partners.
Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
