LG 3DTV 47LW5700 full screen of artifacts on power on
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    today, when my mom turned on her tv to watch the dark knight rises on tv, the picture was fine for a few mins at first, then it deteriorated to a full screen of artifacts like an abstract art painting as shown in the attachment. i tried power cycling the tv but it still turns on and displays the lg logo as a screenful of artifacts. after we tried running the tv for 15 mins, the picture cleared up a bit but it was still very wavy and liney.
    any idea whats wrong with the tv? i only encountered artifacting problems like this when my computers had a gpu that died. could it be either bad caps or a cracked solder joint since the artifacts cleared up a bit when the tv heated up for awhile?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 3DTV 47LW5700 full screen of artifacts on power on
    Service manual to start you off is available
    http://tinyurl.com/zydl969
    • Diah
      • Feb 2013
      • 6437
      did she watch it with 3D ?
      if yes or no, took the tv out from the plug for long time, to reset T.CON
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Panel fault IMO. Try reflowing motherboard.
        • Diah
          • Feb 2013
          • 6437
          IMO... Mr. Panel..
          hard reset enough by IN_Start from any Android Mobile with IR sender..
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3264
            • Singapore
            no she watched it in 2d. it was an analogue OTA broadcast.
            exactly how long is "long"? i tried unplugging it till the standby light went out for about 30 mins and turned it back on but still a similar artifact pattern.
            • Diah
              • Feb 2013
              • 6437
              order menu by RC, if it show make factory reset, if not show menu
              use In_STOP then put code 0413 TV will go standby them after while you turn it on.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                IMO... Mr. Panel..
                Its PanelBurger to you ! Also IMO=In My Opinion.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Try reflowing the motherboard I bet the Bga solder is failing as you said it cleared up.
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • spice_disc
                    Vizio TV M50-C1 reboot cycle and static on screen
                    by spice_disc
                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                    09-08-2024, 02:37 PM
