Need Help Repairing BN44-00197 board
  • Tech 57
    • Aug 2014
    • 37
    Working on a Samsung LN40a530
    Dead subbed another power board so this is the problem.
    Changed caps not a cap problem.I just don't know what other component can cause this
    I have 12v the 5v line at the plug that goes to the main should be 5v only reading 2.2v
    I have other boards here that have the same problem.
    Has anyone rebuilt one of these besides the cap problem
    Any Ideas other than replacing the board
    Thanks ???
  • Diah
    • Feb 2013
    • 6614
    Re: Need Help Repairing BN44-00197 board
    voltage supply levels. derived from +5v. Ex; 2.5v and 3.3v using
    buck regulators.
    change IC regulator
      Thanks ???
      Are you saying the DCV for the STB5.3V PIN 3 and the SWITCHED 5.3V (pin 13~16) at the power supply output connector CN801 are only show 2.2V?
      The STB5.3V and the switched 5.3V (through SWITCHED MOSFET QM806), and switched 13V (through SWITCHED MOSFET QM804) are generated by the same power transformer TM801 as shown in SCH BN44-00197A, no Buck regulator.
      http://www.shopjimmy.com/catalogsear.../?q=BN44-00197
      BTW, please upload good clear pictures of the top and bottom side of YOUR board.
        buck regulators.
        change IC regulator
        Sorry, that is not true on this power supply board, see the diagrams.
        • Diah
          • Feb 2013
          • 6614
          i was talking on DC to Dc on main board.. thanks for the manual as i don't have them.
          • Tech 57
            • Aug 2014
            • 37
            fault is the power board main board is good
            I put in another power board works fine so the power board is at fault.
            still trying to find out the defective part on the power board
              That is why we need to know which 5.3V is low, the STBY or the Switched 5.3V
              • Diah
                • Feb 2013
                • 6614
                if you have so many power board , and you replace .. just now you asking on fault.. common be more serious.. many here can smell tV smoke from writing.
                • Tech 57
                  • Aug 2014
                  • 37
                  @ diah excuse me what are you talking about ?
                  I'm asking for helpful advise if you don't want to help then don't.
                  It would be nice if the fault component was found then that would help anyone that ran into this problem.The boards i have are junk and have major problems by lightning so those are trash.
                  If I can't find the answer I will just have it replaced.
                  Thanks everyone that was trying to help.
                    He probably used the Google translator of some sort to translate German to English so it does not come out quite right.
                    • ebenedekfi
                      • Aug 2016
                      • 6
                      • Románia
                      I have the same board BN44-00197A.
                      In first stage I changed following caps: CM804, CM806, CM809, CM812, CM810, CM808
                      Resistor RM851, RM852, RM853 are burnt, i changed it, and I changed the IC ICM802 too.
                      Now my problem:
                      Standby voltage 5.3V is OK, if the mainbord is not plugged in, but if plugged in MB the standby voltage become 2.1V-2.3V instable. without MB the power supply starting ok, 13V ok, 12V on inverter ok.
                      Please help.
                      Endre
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • Soulzink
                        Samsug washing machine. Power supply DC41-00189a board issue
                        by Soulzink
                        I am trying to fix a samsung washinmachine power supply main board.
                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                        The power supply board reference is the following: DC41-00189a
                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                        04-19-2025, 06:26 AM
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
