Uniden LCD TV power supply help
  • BigPete
    • Jul 2012
    • 69
    • New Zealand
    I have a rare 42inch 1080P Uniden TV with a PK-0043CA power supply.
    The power supply is full with Rubycon YXA capacitors and Panasonic inductors.
    Unfortunately it has failed.
    The list of failed parts that I know of are:
    2kV 222K disc cap
    1000V RU2C Diode https://cdn.badcaps-static.com/pdfs/...5711cea6d2.pdf
    Skanken str-x6769 regulator https://cdn.badcaps-static.com/pdfs/...4cf767d514.pdf
    Unknown resistor
    The regulator IC is on order.
    The disc cap has been replaced
    I will replace the RU2C with a 1N4007 Diode https://cdn.badcaps-static.com/pdfs/...29330501fc.pdf hopefully this is fine.
    The problem I have is the unknown resistor. It is completely fried.
    The resistor was connected to pin 7 of the Sanken STR-X6769 IC which is the Overcurrent Protection/Bottom Detection pin.
    Pin 7 splits into 2 paths, one path goes to a diode(not the faulty one) the other goes through the unknown resistor to the negative of the main bridge rectifier.
    Looking for schematics has been fruitless. Does anyone know what size resistor needs to go in. While i'm picking it will be a guess, where should I start, high resistance or low resistance?
    Is there anymore info that is needed?
    Cheers
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Uniden LCD TV power supply help
    Here is one application which may help you.
      RU2C is Fast switching diode with 180nS Trr, 1N4007 is general purpose diode.
        The Source Resistor on pin 2 (S) is more likely to burnt out too when the Snubber cap or the Power MOSFET inside the STR shorted out.
        How about up loading good clear pictures of this PS.
        • BigPete
          • Jul 2012
          • 69
          • New Zealand
          Thanks Dick for that picture, it's a massive help. The whole circuit is virtually the same. A 100 ohm resistor is what I need.
          Budm - I should've known better. The ease of going to the local electronics store clouded my judgement. This diode should be better then: http://nz.rs-online.com/web/p/products/7743600/. The Source resistors are indeed failed. Thanks for pointing that out.
          I'll get a pic up later. In a rush at the moment.
          Going forward. What will improve power supply reliability? Replacing the source resistors with higher wattage ones and/or the 100 ohm resistor with a higher wattage version? The unknown 100 ohm resistor was only about 5mm long and thin.
          Cheers for the help.
            i think what happen when the IC shorted it, the resistor on pin 7 was also got dumped by the HIGH Voltage (>300VDC) feeding the IC.
            You want those resistors to go open circuit when the IC failed so in case the main fuse did not blow, the resistors were damaged due to the failure of the IC, so when the resistors go open circuit then the current stop flowing which is what you want to happen when the fault occurs instead of heating up the resistors that may burn up other parts nearby and catch on fire.
            The resistors burnt up for reason due to too much current flowing through them.
            • BigPete
              • Jul 2012
              • 69
              • New Zealand
              Thanks Budm. So in short, it was just bad luck that the IC failed?
              • BigPete
                • Jul 2012
                • 69
                • New Zealand
                Or do I have to put a smaller fuse in? It has a 6.3A fuse which seems a lot for an LCD TV.
                • BigPete
                  • Jul 2012
                  • 69
                  • New Zealand
                  Just a follow up on this if anyone has a similar issue. Optocoupler NE004 in Dicks pic above was also faulty. Datasheet for it is:
                  • yurik_avs
                    Power supply ADP-300ER Zener diode parameters unknown
                    by yurik_avs
                    Guys, I have a question about the ADP-300ER power supply. While the spare parts I ordered are on their way, I decided to once again check the piping chains of the burnt mikruh. I found the zener diode in a break, so apparently I didn't detect it right away. His positioner is ZD41. Can anyone tell me its voltage? It is located in the harness of the IC41 NCP1612A3 microcircuit
                    Here is an extract from the datasheet for this chip. This pin is grounded until the PFC output reaches its nominal level. It is also grounded if
                    NCP1612 detects a fault. The rest of the time, i.e. when the PFC...
                    12-12-2023, 05:32 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                    by sam_sam_sam
                    I was working on this CNC machine today found no keyboard functioning no control relay powering on
                    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                    Found shorted diodes on main controller relays there are 3 of them that...
                    01-07-2023, 05:43 PM
                  • Driver8
                    LG EAY57681601 power supply diode
                    by Driver8
                    This is on the power supply/backlight inverter board EAY57681601 for LG 47LH40-UA television. The supply failed when commanded from standby to run, taking out the main fuse. I'm trying to identify diode D601 in the inverter section where the package was blown apart and the markings are gone. Q601 and Q602 will need to be replaced also. If anyone can point me to a schematic that would be most helpful. Also would like to hear if anyone has repaired this type of failure before.
                    09-01-2024, 05:58 PM
