Hello forum,I have a logik 22'' LCD,it has developed a fault,where the standby does light up switches/lights up briefly then switches off back to standby,just reading up could it be more of a firmware fault ? Help please
Logik l22ldvb21
Re: Logik l22ldvb21
Have you measured any voltages on the power supply connectors. Do you have pictures of the circuit boards mounted on the chassis. If you can post those details it would help others help you.Last edited by dick_barton; 03-10-2016, 06:44 AM.Willing to help but I'm no expert. -
Re: Logik l22ldvb21
Yep I have the same board here, bad firmware on mine so chances are same on yours bro. Crappy junk.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: Logik l22ldvb21
Unless you find the FW for the board and panel no
Re: Logik l22ldvb21
You need to reflash the SPI memory Ic outside of the Tv using an SPI analyser. Just get a new board mate as its difficult to do.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by daveytee999I have a cheap Logik TV with DVD unit integrated. It comes on when you press the power button and the Logik logo comes up on screen but then after a few seconds the TV goes back to standby.
Not used to troubleshooting TVs - my background is PCs/Networks/Routers but this looks like it's not a power issue (surely the TV wouldn't power up)
It's not a backlight issue cos the backlight comes on when Logik logo appears.
Have had the TV apart and done basic testing (although just proved that there is mains power and some secondary low voltage coming out).
Not sure... -
by alltvrepairsHi,
I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
Any one met this problem in the past?...10-08-2025, 07:34 AM -
by MrCreosoteWhen compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
4-port Omniview Pro2 f1dz104t
8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
AD ADAPTER:
There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge... -
by _max_Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
Power cable and HDMI cable checked.
No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
by stephan11Hello,
I don't know if I'm in the right place with my problem. I bought a new Dell Latitude 5310 2in1 motherboard. After installation, the orange LED only lights up briefly. can anyone help me here?
greeting
Stephen​07-01-2024, 02:30 PM - Loading...
